Datasheet AD7853, AD7853L (Analog Devices) - 7
Описание3 V to 5 V Single Supply, 200 kSPS, 12-Bit, Serial Sampling ADC
Страниц / Страница34 / 7 — AD7853/AD7853L. PIN FUNCTION DESCRIPTIONS. Pin. Mnemonic. Description
ВерсияB
Формат / Размер файлаPDF / 359 Кб
AD7853/AD7853L PIN FUNCTION DESCRIPTIONS Pin Mnemonic Description
26 предложений от 19 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD7853LARSZ Analogue to Digital Converter, 12Bit, 100KSPS, Single, 3V, 5.5V, SSOP
AD7853LARSZ
506 ₽
ЧипСити
AD7853LARSZ
506 ₽
Зенер
Россия и страны ТС
AD7853LARSZ
от 1 221 ₽
AD7853LARSZ
от 2 502 ₽
1 CONVST Convert Start. Logic Input. A low to high transition on this input puts the track/hold into its hold mode and starts conversion. When this input is not used, it should be tied to DVDD. 2 BUSY Busy Output. The busy output is triggered high by the falling edge of CONVST or rising edge of CAL, and remains high until conversion is completed. BUSY is also used to indicate when the AD7853/AD7853L has completed its on-chip calibration sequence. 3 SLEEP Sleep Input/Low Power Mode. A Logic 0 initiates a sleep and all circuitry is powered down including the internal voltage reference provided there is no conversion or calibration being performed. Calibration data is retained. A Logic 1 results in normal operation. See Power-Down section for more details. 4 REFIN/ Reference Input/Output. This pin is connected to the internal reference through a series resistor and is the REFOUT reference source for the analog-to-digital converter. The nominal reference voltage is 2.5 V and this appears at the pin. This pin can be overdriven by an external reference or can be taken as high as AVDD. When this pin is tied to AVDD, or when an externally applied reference approaches AVDD, the CREF1 pin should also be tied to AVDD. 5 AVDD Analog Positive Supply Voltage, +3.0 V to +5.5 V. 6, 12 AGND Analog Ground. Ground reference for track/hold, reference and DAC. 7 CREF1 Reference Capacitor (0.1 µF multilayer ceramic). This external capacitor is used as a charge source for the internal DAC. The capacitor should be tied between the pin and AGND. 8 CREF2 Reference Capacitor (0.01 µF ceramic disc). This external capacitor is used in conjunction with the on-chip reference. The capacitor should be tied between the pin and AGND. 9 AIN(+) Analog Input. Positive input of the pseudo-differential analog input. Cannot go below AGND or above AVDD at any time, and cannot go below AIN(–) when the unipolar input range is selected. 10 AIN(–) Analog Input. Negative input of the pseudo-differential analog input. Cannot go below AGND or above AVDD at any time. 11 NC No Connect Pin. 13 AMODE Analog Mode Pin. This pin allows two different analog input ranges to be selected. A Logic 0 selects range 0 to VREF (i.e., AIN(+) – AIN(–) = 0 to VREF). In this case AIN(+) cannot go below AIN(–) and AIN(–) cannot go below AGND. A Logic 1 selects range –VREF/2 to +VREF/2 (i.e., AIN(+) – AIN(–) = –VREF/2 to +VREF/2). In this case AIN(+) cannot go below AGND so that AIN(–) needs to be biased to +VREF/2 to allow AIN(+) to go from 0 V to +VREF V. 14 POLARITY Serial Clock Polarity. This pin determines the active edge of the serial clock (SCLK). Toggling this pin will reverse the active edge of the serial clock (SCLK). A Logic 1 means that the serial clock (SCLK) idles high and a Logic 0 means that the serial clock (SCLK) idles low. It is best to refer to the timing diagrams and Table IX for the SCLK active edges. 15 SM1 Serial Mode Select Pin. This pin is used in conjunction with the SM2 pin to give different modes of opera- tion as described in Table X. 16 SM2 Serial Mode Select Pin. This pin is used in conjunction with the SM1 pin to give different modes of opera- tion as described in Table X. 17 CAL Calibration Input. This pin has an internal pull-up current source of 0.15 µA. A Logic 0 on this pin resets all calibration control logic and initiates a calibration on its rising edge. There is the option of connecting a 10 nF capacitor from this pin to DGND to allow for an automatic self-calibration on power-up. This input overrides all other internal operations. If the autocalibration is not required, this pin should be tied to a logic high. 18 DVDD Digital Supply Voltage, +3.0 V to +5.5 V. 19 DGND Digital Ground. Ground reference point for digital circuitry. 20 DOUT Serial Data Output. The data output is supplied to this pin as a 16-bit serial word. 21 DIN Serial Data Input. The data to be written is applied to this pin in serial form (16-bit word). This pin can act as an input pin or as a I/O pin depending on the serial interface mode the part is in (see Table X). 22 CLKIN Master Clock Signal for the device (4 MHz for AD7853, 1.8 MHz for AD7853L). Sets the conversion and calibration times. 23 SCLK Serial Port Clock. Logic input/output. The SCLK pin is configured as an input or output, dependent on the type of serial data transmission (self-clocking or external-clocking) that has been selected by the SM1 and SM2 pins. The SCLK idles high or low depending on the state of the POLARITY pin. 24 SYNC This pin can be an input level triggered active low (similar to a chip select in one case and to a frame sync in the other) or an output (similar to a frame sync) pin depending on SM1, SM2 (see Table X). REV. B –7–
