Datasheet AD7712 (Analog Devices) - 9
ОписаниеCMOS, 24-Bit Sigma-Delta, Signal Conditioning ADC with 2 Analog Input Channels
Страниц / Страница29 / 9 — AD7712. Pin. Mnemonic. Function. TERMINOLOGY. Positive Full-Scale …
ВерсияF
Формат / Размер файлаPDF / 306 Кб
AD7712. Pin. Mnemonic. Function. TERMINOLOGY. Positive Full-Scale Overrange. Integral Nonlinearity. Negative Full-Scale Overrange
AD7712 Pin Mnemonic Function TERMINOLOGY Positive Full-Scale Overrange Integral Nonlinearity Negative Full-Scale Overrange
Микросхема Преобразователь AD, ADC Single Delta-Sigma 1.028KSPS 24Bit Serial 24Pin SOIC W T/R
ЧипСити
AD7712ARZ-REEL
1 861 ₽
AD7712ARZ-REEL7
2 724 ₽
AD7712ARZ-REEL7
SUV System
AD7712ARZ-REEL
21 DRDY Logic Output. A falling edge indicates that a new output word is available for transmission. The DRDY pin will return high upon completion of transmission of a full output word. DRDY is also used to indicate when the AD7712 has completed its on-chip calibration sequence. 22 SDATA Serial Data. Input/output with serial data being written to either the control register or the calibration registers and serial data being accessed from the control register, calibration registers, or the data register. During an output data read operation, serial data becomes active after RFS goes low (provided DRDY is low). During a write operation, valid serial data is expected on the rising edges of SCLK when TFS is low. The output data coding is natural binary for unipolar inputs and offset binary for bipolar inputs. 23 DVDD Digital Supply Voltage, 5 V. DVDD should not exceed AVDD by more than 0.3 V in normal operation. 24 DGND Ground Reference Point for Digital Circuitry.
Positive full-scale overrange is the amount of overhead available This is the maximum deviation of any code from a straight line to handle input voltages on AIN1(+) input greater than passing through the endpoints of the transfer function. The end- (AIN1(–) + VREF/GAIN) or on the AIN2 of greater than +4 ⫻ points of the transfer function are zero-scale (not to be confused VREF/GAIN (for example, noise peaks or excess voltages due to with bipolar zero), a point 0.5 LSB below the first code transi- system gain errors in system calibration routines) without intro- tion (000 . 000 to 000 . 001) and full scale, a point 0.5 LSB ducing errors due to overloading the analog modulator or to above the last code transition (111 . 110 to 111 . 111). The overflowing the digital filter. error is expressed as a percentage of full scale.
Negative Full-Scale Overrange Positive Full-Scale Error
This is the amount of overhead available to handle voltages on Positive full-scale error is the deviation of the last code transi- AIN1(+) below (AIN1(–) – VREF/GAIN) or on AIN2 below tion (111 . 110 to 111 . 111) from the ideal input full-scale –4 ⫻ VREF/GAIN without overloading the analog modulator or voltage. For AIN1(+), the ideal full-scale input voltage is overflowing the digital filter. Note that the analog input will (AIN1(–) + VREF/GAIN – 3/2 LSBs); for AIN2, the ideal full- accept negative voltage peaks on AIN1(+) even in the unipolar scale voltage is +4 ⫻ VREF/GAIN – 3/2 LSBs. Positive full-scale mode provided that AIN1(+) is greater than AIN1(–) and greater error applies to both unipolar and bipolar analog input ranges. than VSS – 30 mV.
Unipolar Offset Error Offset Calibration Range
Unipolar offset error is the deviation of the first code transition In the system calibration modes, the AD7712 calibrates its from the ideal voltage. For AIN1(+), the ideal input voltage is offset with respect to the analog input. The offset calibration (AIN1(–) + 0.5 LSB); for AIN2, the ideal input is 0.5 LSB range specification defines the range of voltages that the AD7712 when operating in the unipolar mode. can accept and still accurately calibrate offset.
Bipolar Zero Error Full-Scale Calibration Range
This is the deviation of the midscale transition (0111 . 111 This is the range of voltages that the AD7712 can accept in the to 1000 . 000) from the ideal input voltage. For AIN1(+), the system calibration mode and still correctly calibrate full scale. ideal input voltage is (AIN1(–) – 0.5 LSB); for AIN2, the ideal
Input Span
input is –0.5 LSB when operating in the bipolar mode. In system calibration schemes, two voltages applied in sequence
Bipolar Negative Full-Scale Error
to the AD7712’s analog input define the analog input range. This is the deviation of the first code transition from the ideal The input span specification defines the minimum and maxi- input voltage. For AIN1(+), the ideal input voltage is (AIN1(–) mum input voltages from zero to full scale that the AD7712 can – VREF/GAIN + 0.5 LSB); for AIN2, the ideal input voltage is accept and still accurately calibrate gain. (–4 ⫻ VREF/GAIN + 0.5 LSB) when operating in the bipolar mode. –8– REV. F Document Outline ANALOG INPUT FUNCTIONS FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE TIMING CHARACTERISTICS PIN CONFIGURATION PIN FUNCTION DESCRIPTION TERMINOLOGY Integral Nonlinearity Positive Full-Scale Error Bipolar Zero Error Bipolar Negative Full-Scale Error Positive Full-Scale Overrange Negative Full-Scale Overrange Offset Calibration Range Full-Scale Calibration Range Input Span Control Register (24 Bits) Filter Selection (FS11–FS0) CIRCUIT DESCRIPTION THEORY OF OPERATION Input Sample Rate DIGITAL FILTERING Filter Characteristics Post Filtering Antialias Considerations ANALOG INPUT FUNCTIONS Analog Input Ranges Burnout Current Bipolar/Unipolar Inputs REFERENCE INPUT/OUTPUT VBIAS Input USING THE AD7712 SYSTEM DESIGN CONSIDERATIONS Clocking System Synchronization Accuracy Autocalibration Self-Calibration System Calibration System Offset Calibration Background Calibration Span and Offset Limits POWER-UP AND CALIBRATION Drift Considerations POWER SUPPLIES AND GROUNDING DIGITAL INTERFACE Self-Clocking Mode Read Operation Write Operation External Clocking Mode Read Operation Write Operation SIMPLIFYING THE EXTERNAL CLOCKING MODE INTERFACE MICROCOMPUTER/MICROPROCESSOR INTERFACING AD7712 to 8051 Interface AD7712 to 68HC11 Interface APPLICATIONS 4–20 mA LOOP OUTLINE DIMENSIONS Revision History
