Datasheet AD5686, AD5684 (Analog Devices) - 5
ОписаниеQuad, 16-/12-Bit nanoDAC+ with SPI Interface
Страниц / Страница27 / 5 — Data Sheet. AD5686/AD5684. AC CHARACTERISTICS. Table 3. Parameter2. Min. …
ВерсияC
Формат / Размер файлаPDF / 757 Кб
Data Sheet. AD5686/AD5684. AC CHARACTERISTICS. Table 3. Parameter2. Min. Typ. Max. Unit. Test Conditions/Comments3
Data Sheet AD5686/AD5684 AC CHARACTERISTICS Table 3 Parameter2 Min Typ Max Unit Test Conditions/Comments3
32 предложений от 18 поставщиков
IC DAC 16BIT V-OUT 16TSSOP. 16 Bit Digital to Analog Converter 4 16-TSSOP. Data Acquisition - Digital to Analog Converters (DAC)...
Рутоника
AD5686BRUZ-RL7
1 006 ₽
Эиком
AD5686BRUZ
от 2 737 ₽
Hi-Tech Circuit Group
AD5686BRUZ
727GS
AD5686BRUZ
link to page 16
VDD = 2.7 V to 5.5 V; VREF = 2.5 V; 1.62 V ≤ VLOGIC ≤ 5.5 V; RL = 2 kΩ to GND; CL = 200 pF to GND; all specifications TMIN to TMAX, unless otherwise noted.1
Table 3. Parameter2 Min Typ Max Unit Test Conditions/Comments3
Output Voltage Settling Time AD5686 5 8 µs ¼ to ¾ scale settling to ±2 LSB AD5684 5 7 µs ¼ to ¾ scale settling to ±2 LSB Slew Rate 0.8 V/µs Digital-to-Analog Glitch Impulse 0.5 nV-sec 1 LSB change around major carry Digital Feedthrough 0.13 nV-sec Multiplying Bandwidth 500 kHz Digital Crosstalk 0.1 nV-sec Analog Crosstalk 0.2 nV-sec DAC-to-DAC Crosstalk 0.3 nV-sec Total Harmonic Distortion4 −80 dB At ambient, BW = 20 kHz, VDD = 5 V, fOUT = 1 kHz Output Noise Spectral Density 100 nV/√Hz DAC code = midscale, 10 kHz; gain = 2, internal reference enabled Output Noise 6 µV p-p 0.1 Hz to 10 Hz SNR 90 dB At ambient, BW = 20 kHz, VDD = 5 V, fOUT = 1 kHz SFDR 83 dB At ambient, BW = 20 kHz, VDD = 5 V, fOUT = 1 kHz SINAD 80 dB At ambient, BW = 20 kHz, VDD = 5 V, fOUT = 1 kHz 1 Guaranteed by design and characterization; not production tested. 2 See the Terminology section. 3 Temperature range is −40°C to +105°C, typical @ 25°C. 4 Digital y generated sine wave @ 1 kHz. Rev. C | Page 5 of 27 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AC CHARACTERISTICS TIMING CHARACTERISTICS DAISY-CHAIN AND READBACK TIMING CHARACTERISTICS Circuit and Timing Diagrams ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION DIGITAL-TO-ANALOG CONVERTER TRANSFER FUNCTION DAC ARCHITECTURE Output Amplifiers SERIAL INTERFACE Input Shift Register STANDALONE OPERATION WRITE AND UPDATE COMMANDS Write to Input Register n (Dependent on LDACB) Update DAC Register n with Contents of Input Register n Write to and Update DAC Channel n (Independent of LDACB) DAISY-CHAIN OPERATION READBACK OPERATION POWER-DOWN OPERATION LOAD DAC (HARDWARE LDACB PIN) Instantaneous DAC Updating (LDACB Held Low) Deferred DAC Updating (LDACB Is Pulsed Low) LDACB MASK REGISTER HARDWARE RESET (RESETB) RESET SELECT PIN (RSTSEL) APPLICATIONS INFORMATION MICROPROCESSOR INTERFACING AD5686/AD5684 TO ADSP-BF531 INTERFACE AD5686/AD5684 TO SPORT INTERFACE LAYOUT GUIDELINES GALVANICALLY ISOLATED INTERFACE OUTLINE DIMENSIONS ORDERING GUIDE
