Оптопары и оптореле Megawin
Datasheet ADA4930-1-EP (Analog Devices) - 4
ОписаниеUltralow Noise Drivers for Low Voltage ADCs
Страниц / Страница12 / 4 — ADA4930-1-EP. Enhanced Product. 3.3 V VOCM TO VO, CM PERFORMANCE. Table …
ВерсияA
Формат / Размер файлаPDF / 202 Кб
ADA4930-1-EP. Enhanced Product. 3.3 V VOCM TO VO, CM PERFORMANCE. Table 2. Parameter Test. Conditions/Comments. Min. Typ. Max. Unit
ADA4930-1-EP Enhanced Product 3.3 V VOCM TO VO, CM PERFORMANCE Table 2 Parameter Test Conditions/Comments Min Typ Max Unit
33 предложений от 15 поставщиков
727GS
ADA4930-1YCPZ-R7
от 24 ₽
Эиком
ADA4930-1YCPZ-R7
от 1 179 ₽
ADA4930-1YCPZ-R7
ADA4930-1YCPZ-R7
Ruimeng предлагает удачную замену популярной микросхеме Axx1248 – 24-битный Σ-Δ АЦП MS5148T
ADA4930-1-EP Enhanced Product 3.3 V VOCM TO VO, CM PERFORMANCE Table 2. Parameter Test Conditions/Comments Min Typ Max Unit
VOCM DYNAMIC PERFORMANCE −3 dB Bandwidth VO, cm = 0.1 V p-p 745 MHz Slew Rate VO, cm = 2 V p-p, 25% to 75% 828 V/μs VOCM INPUT CHARACTERISTICS Input Voltage Range 0.8 1.1 V Input Resistance 7.0 8.3 10.3 kΩ Input Offset Voltage VOS, cm = VO, cm − VOCM; VIP = VIN = VOCM = 0 V −25 +15.4 +31 mV Input Voltage Noise f = 100 kHz 23.5 nV/√Hz Gain 0.99 1 1.02 V/V TMIN to TMAX 1.01 V/V CMRR ∆VOCM = 0.5 V dc; RF = RG = 10 kΩ, RL = open circuit −83 −77 dB TMIN to TMAX −76 dB
3.3 V GENERAL PERFORMANCE Table 3. Parameter Test Conditions/Comments Min Typ Max Unit
POWER SUPPLY Operating Range 3.3 V Quiescent Current per Amplifier Enabled 32 35 40 mA Enabled, TMIN to TMAX variation 81 μA/C Disabled 0.44 1.8 2.35 mA TMIN to TMAX 2.4 mA +PSRR ΔVICM = 0.5 V; RF = RG = 10 kΩ, RL = open circuit −74 −70 dB TMIN to TMAX −68 dB −PSRR ΔVICM = 0.5 V; RF = RG = 10 kΩ, RL = open circuit −87 −76 dB TMIN to TMAX −77 dB POWER-DOWN (PD) PD Input Voltage Disabled <0.8 V Enabled >1.3 V Turn-Off Time 1 μs Turn-On Time 12 ns PD Pin Bias Current Enabled PD = 3.3 V 0.09 μA Disabled PD = 0 V 97 μA OPERATING TEMPERATURE RANGE −55 +105 °C Rev. A | Page 4 of 12 Document Outline Features Enhanced Product Features Applications General Description Functional Block Diagrams Revision History Specifications 3.3 V Operation 3.3 V VOCM to VO, cm Performance 3.3 V General Performance 5 V Operation 5 V VOCM to VO, cm Performance 5 V General Performance Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Outline Dimensions Ordering Guide
