Datasheet ADL5562 (Analog Devices) - 10
Описание3.3 GHz Ultralow Distortion RF/IF Differential Amplifier
Страниц / Страница21 / 10 — ADL5562. Data Sheet. –40. V MAXIMUM. V MID. V MINIMUM. –60. –20. Bc). …
ВерсияF
Формат / Размер файлаPDF / 566 Кб
ADL5562. Data Sheet. –40. V MAXIMUM. V MID. V MINIMUM. –60. –20. Bc). –80. N HD2 (. N HD3 (. O –100. C DI. –120. –140. –100. HARM. –160. 100. 150. 200. 250
ADL5562 Data Sheet –40 V MAXIMUM V MID V MINIMUM –60 –20 Bc) –80 N HD2 ( N HD3 ( O –100 C DI –120 –140 –100 HARM –160 100 150 200 250
Усилитель, ANALOG DEVICES ADL5562ACPZ-WP IC, DIFFER AMP, 3.3GHz, RF, 16LFCSP
ADL5562ACPZ-WP
421 ₽
ЧипСити
ADL5562ACPZ-WP
715 ₽
ADL5562ACPZ-WP
ADL5562ACPZ-WP
ADL5562 Data Sheet –40 0 –40 0 A A V MAXIMUM V MAXIMUM A A V MID V MID A A V MINIMUM V MINIMUM –60 –20 –60 –20 Bc) Bc) Bc) Bc) d d d d –80 –40 –80 –40 N HD2 ( N HD3 ( N HD2 ( N HD3 ( IO IO IO IO RT RT RT RT O –100 –60 O O –100 –60 O T T T T S S S S C DI C DI C DI C DI –120 –80 NI NI –120 –80 NI NI O O O O –140 –100 HARM HARM –140 –100 HARM HARM –160 –120 –160 –120 0 50 100 150 200 250
021
024
FREQUENCY (MHz)
08003-
FREQUENCY (MHz)
08003- Figure 15. Harmonic Distortion (HD2/HD3) vs. Frequency at AV = 6 dB, Figure 18. Harmonic Distortion (HD2/HD3) vs. Frequency at Av = 6 dB, AV = 12 dB, and AV = 15.5 dB, Output Level at 2 V p-p, RL = 200 Ω Av = 12 dB, and Av = 15.5 dB, Output Level at 2 V p-p, RL = 1 kΩ
–40 0 –20 +85°C +25°C –40°C –30 –60 –20 Bc) Bc) ) d d c –40 dB ( –80 –40 N HD2 ( N HD3 ( –50 IO IO TION RT RT OR T O –100 –60 O –60 T T S S S C DI C DI C DI –70 NI –120 –80 HD2 NI NI O O O –80 HARM HD3 –140 –100 HARM HARM –90 –160 –120 –100 0 50 100 150 200 250
022 029
–2 –1 0 1 2 3 4 5
08003-
FREQUENCY (MHz) P
08003-
OUT (dBm)
Figure 16. Harmonic Distortion (HD2/HD3) vs. Frequency, Figure 19. Harmonic Distortion (HD2/HD3) vs. Power (POUT), Three Temperatures, Output Level at 2 V p-p, RL = 200 Ω Frequency 140 MHz, AV = 15.5 dB
–40 0 –60 –50 +85°C +25°C AV MAXIMUM –40°C –65 A –55 V MID –60 –20 AV MINIMUM Bc) Bc) d d Bc) –70 –60 Bc) d d –75 –65 –80 –40 N HD2 ( N HD3 ( N HD2 ( N HD3 ( IO IO –80 –70 IO IO RT RT RT RT O –100 –60 O –85 –75 T T O O S S T T S S –90 –80 C DI C DI –120 –80 C DI C DI NI NI NI NI O O –95 –85 O O –100 –90 –140 –100 HARM HARM HARM HARM –105 –95 –160 –120 –110 –100 0 50 100 150 200 250
023
008
FREQUENCY (MHz)
08003-
FREQUENCY (MHz)
08003- Figure 17. Harmonic Distortion (HD2/HD3) vs. Frequency, Over Temperature, Figure 20. Harmonic Distortion (HD2/HD3) vs. Frequency (Single-Ended Input) Output Level at 2 V p-p, RL = 1 kΩ Rev. F | Page 10 of 21 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE APPLICATIONS INFORMATION BASIC CONNECTIONS INPUT AND OUTPUT INTERFACING Single-Ended Input to Differential Output GAIN ADJUSTMENT AND INTERFACING ADC INTERFACING LAYOUT CONSIDERATIONS SOLDERING INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
