Datasheet ADL5561 (Analog Devices) - 6
Описание2.9 GHz Ultralow Distortion RF/IF Differential Amplifier
Страниц / Страница25 / 6 — Data Sheet. ADL5561. Parameter. Conditions. Min. Typ. Max. Unit
ВерсияG
Формат / Размер файлаPDF / 773 Кб
Data Sheet ADL5561 Parameter Conditions Min Typ Max Unit
26 предложений от 14 поставщиков
Микросхема Буферный усилитель, ANALOG DEVICES ADL5561ACPZ-R7 RF Amplifier IC, 15.5dB Gain / 8dB Noise, 10MHz to 2.9GHz, 3V to 3.6V, LFCSP-16...
ADL5561ACPZ-R7
761 ₽
ADL5561ACPZ-R7
от 1 095 ₽
ADL5561ACPZ-R7
от 1 781 ₽
ADL5561ACPZ-R7
link to page 15
250 MHz NOISE/HARMONIC PERFORMANCE Second/Third Harmonic Distortion AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p −80/−73 dBc AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p −76/−70 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p −78/−72 dBc Output Third-Order Intercept/Third-Order AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p +41/−86 dBm/dBc Intermodulation Distortion composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p +40/−84 dBm/dBc composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p +39/−83 dBm/dBc composite (2 MHz spacing) Noise Spectral Density (RTI) AV = 6 dB 3.2 nV/√Hz AV = 12 dB 2.2 nV/√Hz AV = 15.5 dB 1.7 nV/√Hz 1 dB Compression Point (RTO) AV = 6 dB 12 dBm AV = 12 dB 12 dBm AV = 15.5 dB 12 dBm 500 MHz NOISE/HARMONIC PERFORMANCE Second/Third Harmonic Distortion AV = 6 dB, RL = 200 Ω, VOUT = 1 V p-p −69/−57 dBc AV = 12 dB, RL = 200 Ω, VOUT = 1 V p-p −72/−60 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 1V p-p −66/−61 dBc Output Third-Order Intercept/Third-Order AV = 6 dB, RL = 200 Ω, VOUT = 1 V p-p +40/−97 dBm/dBc Intermodulation Distortion composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = 1 V p-p +36/−90 dBm/dBc composite( 2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = 1 V p-p +34/−75 dBm/dBc composite (2 MHz spacing) Noise Spectral Density (RTI) AV = 6 dB 4.1 nV/√Hz AV = 12 dB 2.4 nV/√Hz AV = 15.5 dB 1.8 nV/√Hz 1000 MHz NOISE/HARMONIC PERFORMANCE Second/Third Harmonic Distortion AV = 6 dB, RL = 200 Ω, VOUT = 1 V p-p −58/−53 dBc AV = 12 dB, RL = 200 Ω, VOUT = 1 V p-p −55/−50 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 1 V p-p −57/−50 dBc Output Third-Order Intercept/Third-Order AV = 6 dB, RL = 200 Ω, VOUT = 1 V p-p +18/−54 dBm/dBc Intermodulation Distortion composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = 1 V p-p +18/−56 dBm/dBc composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = 1 V p-p +18/−46 dBm/dBc composite (2 MHz spacing) Noise Spectral Density (RTI) AV = 6 dB 6 nV/√Hz AV = 12 dB 2.6 nV/√Hz AV = 15.5 dB 1.8 nV/√Hz 1 See the Applications Information section for a discussion of single-ended input, dc-coupled operation. Rev. G | Page 5 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE APPLICATIONS INFORMATION BASIC CONNECTIONS INPUT AND OUTPUT INTERFACING Single-Ended Input to Differential Output GAIN ADJUSTMENT AND INTERFACING ADC INTERFACING LAYOUT CONSIDERATIONS SOLDERING INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
