Datasheet AD8138-EP (Analog Devices) - 4
ОписаниеLow Distortion Differential ADC Driver
Страниц / Страница12 / 4 — AD8138-EP. VOCM TO ±OUT SPECIFICATIONS. Table 2. Parameter Conditions. …
Формат / Размер файлаPDF / 195 Кб
AD8138-EP. VOCM TO ±OUT SPECIFICATIONS. Table 2. Parameter Conditions. Min. Typ. Max. Unit
AD8138-EP VOCM TO ±OUT SPECIFICATIONS Table 2 Parameter Conditions Min Typ Max Unit
44 предложений от 22 поставщиков
Микросхема Буферный усилитель, SP Amp Differential ADC Driver Single ±5.5V/11V 8Pin SOIC N T/R
AD8138ARZ-R7
от 194 ₽
AD8138ARZ-R7
288 ₽
ЧипСити
AD8138ARZ-R7
320 ₽
Элевика
AD8138ARZ-R7
442 ₽
link to page 4 link to page 4 link to page 4 link to page 4
At 25°C, VS = ±5 V, VOCM = 0 V, G = +1, RL, dm = 500 Ω, unless otherwise noted. All specifications refer to single-ended input and differential outputs, unless otherwise noted.
Table 2. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth 250 MHz Slew Rate 330 V/μs INPUT VOLTAGE NOISE (RTI) f = 0.1 MHz to 100 MHz 17 nV/√Hz DC PERFORMANCE Input Voltage Range ±3.8 V Input Resistance 200 kΩ Input Offset Voltage VOS, cm = VOUT, cm; VDIN+ = VDIN– = VOCM = 0 V −3.5 ±1 +3.5 mV T 1 MIN to TMAX −10.2 +10.2 mV Input Bias Current 0.5 μA VOCM CMRR ΔVOUT, dm/ΔVOCM; ΔVOCM = ±1 V −75 dB Gain ΔV 1 OUT, cm/ΔVOCM; ΔVOCM = ±1 V, TMIN to TMAX 0.9955 1 1.0045 V/V POWER SUPPLY Operating Range ±1.4 ±5.5 V Quiescent Current 18 20 23 mA T 1 MIN to TMAX 13.2 mA Power Supply Rejection Ratio ΔV 1 OUT, dm/ΔVS; ΔVS = ±1 V, TMIN to TMAX −90 −70 dB OPERATING TEMPERATURE RANGE −55 +105 °C 1 Specified to ±6 sigma over the −55°C to +105°C operating temperature range. Rev. 0 | Page 4 of 12 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TYPICAL APPLICATION CIRCUIT TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION MAXIMUM OUTPUT VOLTAGE SWING PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
