Datasheet AD8229 (Analog Devices) - 2
Описание1 nV/√Hz Low Noise 210°C Instrumentation Amplifier
Страниц / Страница25 / 2 — AD8229* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
ВерсияB
AD8229* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Press. EVALUATION KITS
AD8229* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Press EVALUATION KITS
View a parametric search of comparable parts.
Press
• Analog Devices Introduces Industry’s Fastest, Most
EVALUATION KITS
Accurate and Lowest Power High-Temperature SAR A/D Converter • AD62x, AD822x, AD842x Series InAmp Evaluation Board
Technical Articles DOCUMENTATION
• MS-2707: Harsh Environments Conquered - Low Power, Precision, High Temperature Components for Extreme
Application Notes
High Temperature Applications • AN-1401: Instrumentation Amplifier Common-Mode Range: The Diamond Plot
DESIGN RESOURCES Data Sheet
• AD8229 Material Declaration • AD8229: 1nV/√Hz Low Noise 210°C Instrumentation • PCN-PDN Information Amplifier Data Sheet • Quality And Reliability
User Guides
• Symbols and Footprints • UG-261: Evaluation Boards for the AD62x, AD822x and AD842x Series
DISCUSSIONS TOOLS AND SIMULATIONS
View all AD8229 EngineerZone Discussions. • AD8229 SPICE Macro-Model
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Predicted Lifetime vs. Operating Temperature Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Architecture Gain Selection RG Power Dissipation Reference Terminal Input Voltage Range Layout Common-Mode Rejection Ratio over Frequency Power Supplies Reference Pin Input Bias Current Return Path Input Protection Input Voltages Beyond the Rails Large Differential Input Voltage at High Gain IMAX Radio Frequency Interference (RFI) Calculating the Noise of the Input Stage Source Resistance Noise Voltage Noise of the Instrumentation Amplifier Current Noise of the Instrumentation Amplifier Total Noise Density Calculation Outline Dimensions Ordering Guide
