Datasheet AD8229 (Analog Devices) - 8
Описание1 nV/√Hz Low Noise 210°C Instrumentation Amplifier
Страниц / Страница25 / 8 — Data Sheet. AD8229. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –IN. …
ВерсияB
Data Sheet. AD8229. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –IN. +VS. VOUT. REF. +IN. –VS. TOP VIEW. (Not to Scale)
Data Sheet AD8229 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS –IN +VS VOUT REF +IN –VS TOP VIEW (Not to Scale)
Data Sheet AD8229 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS AD8229 –IN 1 8 +VS RG 2 7 VOUT RG 3 6 REF +IN 4 5 –VS
003
09412- Figure 4. Pin Configuration
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1 −IN Negative Input Terminal. 2, 3 RG Gain Setting Terminals. Place resistor across the RG pins to set the gain. G = 1 + (6 kΩ/RG). 4 +IN Positive Input Terminal. 5 −VS Negative Power Supply Terminal. 6 REF Reference Voltage Terminal. Drive this terminal with a low impedance voltage source to level-shift the output. 7 VOUT Output Terminal. 8 +VS Positive Power Supply Terminal. Rev. B | Page 7 of 24 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Predicted Lifetime vs. Operating Temperature Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Architecture Gain Selection RG Power Dissipation Reference Terminal Input Voltage Range Layout Common-Mode Rejection Ratio over Frequency Power Supplies Reference Pin Input Bias Current Return Path Input Protection Input Voltages Beyond the Rails Large Differential Input Voltage at High Gain IMAX Radio Frequency Interference (RFI) Calculating the Noise of the Input Stage Source Resistance Noise Voltage Noise of the Instrumentation Amplifier Current Noise of the Instrumentation Amplifier Total Noise Density Calculation Outline Dimensions Ordering Guide
