Datasheet AD8229-KGD (Analog Devices) - 5
Описание1 nV/√Hz Low Noise 210°C Instrumentation Amplifier
Страниц / Страница8 / 5 — Known Good Die. AD8229-KGD. Parameter. Test Conditions/Comments. Min. …
Формат / Размер файлаPDF / 148 Кб
Known Good Die. AD8229-KGD. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Known Good Die AD8229-KGD Parameter Test Conditions/Comments Min Typ Max Unit
21 предложений от 15 поставщиков
Микросхема Усилитель прибора, ANALOG DEVICES AD8229HDZ Instrument Amplifier, 1 Amplifier, 100µV, 22V/µs, 15MHz, ± 4V to ± 17V, DIP
AD8229HDZ
19 333 ₽
AD8229HDZ
25 028 ₽
AD8229HDZ
37 790 ₽
Элитан
AD8229HDZ
58 697 ₽
link to page 6 link to page 6 link to page 5
POWER SUPPLY Operating Range ±4 ±17 V Quiescent Current 6.7 7 mA High Temperature T = 210°C 12 mA A TEMPERATURE RANGE For Specified Performance5 −40 +210 °C 1 Total Voltage Noise = √(e 2 2 ni + (eno/G)2)+ eRG ). 2 These specifications do not include the tolerance of the external gain setting resistor, RG. For G>1, RG errors should be added to the specifications given in this table. 3 Differential and common-mode input impedance can be calculated from the pin impedance: ZDIFF = 2(ZPIN); ZCM = ZPIN/2. 4 Input voltage range of the AD8229-KGD input stage only. The input range can depend on the common-mode voltage, differential voltage, gain, and reference voltage. 5 Performance at 210°C is guaranteed for 1000 hours assuming that the maximum junction temperature listed in the Absolute Maximum Ratings, Table 2 is not exceeded. Rev. 0 | Page 5 of 8 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings ESD Caution Pad Configuration and Function Descriptions Outline Dimensions Die Specifications and Assembly Recommendations Ordering Guide
