Оптопары и оптореле Megawin
Datasheet AD526 (Analog Devices) - 10
ОписаниеSoftware Programmable Gain Amplifier
Страниц / Страница15 / 10 — AD526. TIMING AND CONTROL. DIGITAL FEEDTHROUGH. Table I. Logic Input …
ВерсияD
Формат / Размер файлаPDF / 505 Кб
AD526. TIMING AND CONTROL. DIGITAL FEEDTHROUGH. Table I. Logic Input Truth Table. Gain Code. Control. Condition. A2 A1 A0 B
AD526 TIMING AND CONTROL DIGITAL FEEDTHROUGH Table I Logic Input Truth Table Gain Code Control Condition A2 A1 A0 B
22 предложений от 16 поставщиков
Микросхема Буферный усилитель, ANALOG DEVICES AD526BDZ Programmable/Variable Amplifier, 1Channels, 1 Amplifier, 4MHz, -40℃, 85℃, ± 4.5V to ± 16.5V
ЧипСити
AD526BDZ
245 ₽
Элитан
AD526BDZ
10 319 ₽
AD526BDZ
AD526BDZ
With either CS or CLK or both held high, the AD526 gain state
will remain constant regardless of the transitions at the A0, A1, A2 or B inputs. However, high speed logic transitions will un-
avoidably feed through to the analog circuitry within the AD526
A2 A1 A0 B CLK (CS = 0) Gain Condition
causing spikes to occur at the signal output. X X X X 1 Previous State Latched This feedthrough effect can be completely eliminated by operat- 0 0 0 1 0 1 Transparent ing the AD526 in the transparent mode and latching the gain 0 0 1 1 0 2 Transparent code in an external bank of latches (Figure 36). 0 1 0 1 0 4 Transparent To operate the AD526 using serial inputs, the configuration 0 1 1 1 0 8 Transparent shown in Figure 36 can be used with the 74LS174 replaced by a 1 X X 1 0 16 Transparent serial-in/parallel-out latch, such as the 54LS594. X X X 0 0 1 Transparent X X X 0 1 1 Latched
A1 A0 A2 B +5V
0 0 0 1 1 1 Latched 0 0 1 1 1 2 Latched
1
m
F
0 1 0 1 1 4 Latched
TIMING 74LS174 SIGNAL
0 1 1 1 1 8 Latched 1 X X 1 1 16 Latched
+VS
NOTE: X = Don’t Care.
0.1
m
F
The specifications on page 3, in combination with Figure 35, give the timing requirements for loading new gain codes.
OUT 16 15 14 13 12 11 10 9 FORCE A1 A0 CS CLK A2 B GAIN CODE LOGIC AND LATCHES VALID DATA INPUTS 16 8 4 2 1 TC VOUT GAIN NETWORK CLK OR CS T T S H AD526 + TC = MINIMUM CLOCK CYCLE NOTE: THRESHOLD LEVEL FOR 1 2 3 4 5 6 7 8 OUT T GAIN CODE, CS, AND CLK IS 1.4V. S = DATA SETUP TIME SENSE TH = DATA HOLD TIME 0.1
m
F V
Figure 35. AD526 Timing
IN –VS
Figure 36. Using an External Latch to Minimize Digital Feedthrough REV. D –9–
