Клеммники KEEN SIDE
Datasheet ADUM4190 (Analog Devices) - 8
ОписаниеHigh Stability Isolated Error Amplifier
Страниц / Страница15 / 8 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/17602
Формат / Размер файлаPDF / 613 Кб
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/17602
34 предложений от 11 поставщиков
IC: усилитель погрешности; 400кГц; Ch: 1; 3÷20В; SO16-EP; ±1%
ADUM4190TRIZ-EP
от 85 ₽
ADUM4190TRIZ-EP
247 ₽
Элитан
ADUM4190TRIZ-EP
629 ₽
ADUM4190TRIZ-EP
от 646 ₽
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions 2/ Temperature, Device Limits Unit TA type Min Max Power supply. Side 1 operating range VDD1 -55C to +125C 01 3.0 20 V Side 2 operating range VDD2 -55C to +125C 01 3.0 20 V Power supply rejection DC, VDD1 = VDD2 = 3.0 V to 20 V -55C to +125C 01 60 dB Supply current IDD1 See figure 7 -55C to +125C 01 2.0 mA 25C 1.4 typical IDD2 See figure 8 -55C to +125C 5.0 25C 2.9 typical Package characteristics. Input to output 5/ RI-O 25C 01 1013 typical resistance Input to output 5/ CI-O f = 1 MHz 25C 01 2.2 typical pF capacitance Input capacitance 6/ CI 25C 01 4.0 typical pF Integrated circuit JA Thermocouple located at center of 25C 01 45 typical C/W junction to ambient package underside thermal resistance 1/ Testing and other quality control techniques are used to the extent deemed necessary to assure product performance over the specified temperature range. Product may not necessarily be tested across the full temperature range and all parameters may not necessarily be tested. In the absence of specific parametric testing, product performance is assured by characterization and/or design. 2/ Unless otherwise specified, VDD1 = VDD2 = 3 V to 20 V for TA = -55C to +125C and all typical specifications are at TA = +25C. 3/ Output gain defined as the slope of the best fit line of the output voltage versus the input voltage over the specified input range, with the offset error adjusted out. 4/ Output linearity is defined as the peak to peak output deviation from the best fit line of the output gain, expressed as a percentage of the full scale output voltage. 5/ The device is considered a 2 terminal device; pin1 through 8 are shorted together, and pin 9 through pin 16 are shorted together. 6/ Input capacitance is from any input pin to ground.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/17602
REV PAGE 8
