Datasheet ADUM4190-EP (Analog Devices) - 5
ОписаниеHigh Stability Isolated Error Amplifier
Страниц / Страница14 / 5 — Enhanced Product. ADuM4190-EP. INSULATION AND SAFETY RELATED …
Формат / Размер файлаPDF / 483 Кб
Enhanced Product. ADuM4190-EP. INSULATION AND SAFETY RELATED SPECIFICATIONS. Table 4. Parameter. Symbol Value. Unit
Enhanced Product ADuM4190-EP INSULATION AND SAFETY RELATED SPECIFICATIONS Table 4 Parameter Symbol Value Unit
40 предложений от 15 поставщиков
Микросхема Развязывающий усилитель, ANALOG DEVICES ADUM4190TRIZ Isolation Amplifier, High Stability Error, 1 Amplifier, 5kV, 3V to 20V, SOIC, 16Pins
ADUM4190TRIZ-RL
141 ₽
ADUM4190TRIZ-EP-RL
227 ₽
ADUM4190TRIZ
от 501 ₽
ADUM4190TRIZ
Enhanced Product ADuM4190-EP INSULATION AND SAFETY RELATED SPECIFICATIONS Table 4. Parameter Symbol Value Unit Test Conditions/Comments
Rated Dielectric Insulation Voltage 5000 V rms 1-minute duration Minimum External Air Gap (Clearance) L(I01) 8.0 min mm Measured from input terminals to output terminals, shortest distance through air along the PCB mounting plane, as an aid to PCB layout Minimum External Tracking (Creepage) L(I02) 8.3 min mm Measured from input terminals to output terminals, shortest distance path along body Minimum Internal Gap (Internal Clearance) 0.017 min mm Insulation distance through insulation Tracking Resistance (Comparative Tracking Index) CTI >400 V DIN IEC 112/VDE 0303, Part 1 Isolation Group II Material Group DIN VDE 0110, 1/89, Table 1
RECOMMENDED OPERATING CONDITIONS Table 5. Parameter Symbol Min Typ Max Unit
OPERATING TEMPERATURE T −55 +125 °C A SUPPLY VOLTAGES1 V , V 3.0 20 V DD1 DD2 INPUT SIGNAL RISE AND FALL TIMES t , t 1.0 ms R F 1 All voltages are relative to their respective grounds. Rev. 0 | Page 5 of 14 Document Outline FEATURES ENHANCED FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS PACKAGE CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY RELATED SPECIFICATIONS RECOMMENDED OPERATING CONDITIONS DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 INSULATION CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
