Datasheet ADL5910 (Analog Devices) - 4
ОписаниеDC to 6 GHz, ≤45 dB Envelope Threshold Detector/Trigger
Страниц / Страница22 / 4 — ADL5910. Data Sheet. Parameter. Test Conditions/Comments. Min Typ. Max. …
ADL5910. Data Sheet. Parameter. Test Conditions/Comments. Min Typ. Max. Unit
ADL5910 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
20 предложений от 9 поставщиков
РЧ детектор, 0Гц до 6ГГц, -30дБм до 15дБм входная мощность, 3.15В до 3.45В, LFCSP-16
ADL5910ACPZN-R7
261 ₽
ADL5910ACPZN-R7
666 ₽
ADL5910ACPZN-R7
от 696 ₽
ADL5910ACPZN-R7
link to page 6 link to page 6 link to page 6
f = 900 MHz ±1.0 dB Input Range 45 dB ±1.0 dB Input Level Maximum Three-point calibration at −20 dBm, 0 dBm, and +10 dBm 17 dBm Minimum −28 dBm VIN− Setpoint Voltage For threshold detection at 10 dBm 752 mV For threshold detection at 0 dBm 241 mV For threshold detection at −10 dBm 81 mV Threshold Variation vs. −40°C < TA < +85°C, PIN ≈ 10 dBm ±0.1 dB Temperature −40°C < TA < +85°C, PIN ≈ 0 dBm −0.2/+0.11 dB −40°C < TA < +85°C, PIN ≈ −10 dBm 0.1/0.31 dB −40°C < TA < +105°C, PIN ≈ 10 dBm ±0.1 dB −40°C < TA < +105°C, PIN ≈ 0 dBm −0.2/+0.11 dB −40°C < TA < +105°C, PIN ≈ −10 dBm 0.1/0.31 dB f = 1900 MHz ±1.0 dB Input Range 45 dB ±1.0 dB Input Level Maximum Three-point calibration at −20 dBm, 0 dBm, and +10 dBm 17 dBm Minimum −28 dBm VIN− Setpoint Voltage For threshold detection at 10 dBm 774 mV For threshold detection at 0 dBm 241 mV For threshold detection at −10 dBm 78 mV Threshold Variation vs. −40°C < TA < +85°C, PIN ≈ 10 dBm −0.2/+0.11 dB Temperature −40°C < TA < +85°C, PIN ≈ 0 dBm −0.1/01 dB −40°C < TA < +85°C, PIN ≈ −10 dBm ±0.2 dB −40°C < TA < +105°C, PIN ≈ 10 dBm −0.2/+0.11 dB −40°C < TA < +105°C, PIN ≈ 0 dBm −0.1/01 dB −40°C < TA < +105°C, PIN ≈ −10 dBm ±0.2 dB f = 2600 MHz ±1.0 dB Input Range 43.5 dB ±1.0 dB Input Level Maximum Three-point calibration at −20 dBm, 0 dBm, and +10 dBm 16 dBm Minimum −27.5 dBm VIN− Setpoint Voltage For threshold detection at 10 dBm 775 mV For threshold detection at 0 dBm 236 mV For threshold detection at −10 dBm 76 mV Threshold Variation vs. −40°C < TA < +85°C, PIN ≈ 10 dBm −0.3/+0.11 dB Temperature −40°C < TA < +85°C, PIN ≈ 0 dBm −0.2/01 dB −40°C < TA < +85°C, PIN ≈ −10 dBm −0.4/−0.11 dB −40°C < TA < +105°C, PIN ≈ 10 dBm −0.3/+0.11 dB −40°C < TA < +105°C, PIN ≈ 0 dBm −0.2/01 dB −40°C < TA < +105°C, PIN ≈ −10 dBm −0.4/−0.11 dB Rev. 0 | Page 4 of 22 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC CONNECTIONS Q AND QB RESPONSE TIME SETTING THE VIN− THRESHOLD DETECTION VOLTAGE APPLICATIONS INFORMATION A COMPLETE INPUT PROTECTION CIRCUIT RESET ON ENABLE OR AT POWER-UP IMPROVING FREQUENCY FLATNESS EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
