Datasheet ADL6010 (Analog Devices) - 9
ОписаниеFast Responding, 45 dB Range, 0.5 GHz TO 43.5 GHz Envelope Detector
Страниц / Страница22 / 9 — Data Sheet. ADL6010. TYPICAL PERFORMANCE CHARACTERISTICS. 2.6. 2.4. …
ВерсияC
Data Sheet. ADL6010. TYPICAL PERFORMANCE CHARACTERISTICS. 2.6. 2.4. +125°C. mA) 2.2. E (V). +85°C. G 3. 2.0. +25°C. T V. CURRE. U 2. Y 1.8
Data Sheet ADL6010 TYPICAL PERFORMANCE CHARACTERISTICS 2.6 2.4 +125°C mA) 2.2 E (V) +85°C G 3 2.0 +25°C T V CURRE U 2 Y 1.8
link to page 15 link to page 15
VPOS = 5.0 V, CLOAD = open, TA = 25°C, unless otherwise specified. Error referred to slope and intercept at indicated calibration points. Single-ended input drive, input RF signal is a continuous sine wave, unless otherwise noted.
5 2.6 4 2.4 +125°C mA) 2.2 E (V) ( +85°C G 3 A NT LT 2.0 O +25°C T V CURRE U 2 Y 1.8 L TP VPOS = 4.75V PP OU V –40°C POS = 5.00V SU 1.6 VPOS = 5.25V 1 –55°C 1.4
004 005 1617- 1617- 1
0 1.2
1
–40 –35 –30 –25 –20 –15 –10 –5 0 5 10 15 20 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 15 20 PIN (dBm) PIN (dBm)
Figure 3. Output Voltage (VOUT) vs. RF Input Power (PIN) for Figure 6. Supply Current vs. RF Input Power (PIN) for Various Temperatures Various Supply Voltages
0 1 0 –1 –5 B) d –2 N ( AI B) –3 d –10 D G 1 ( E S1 IZ –4 AL RM –5 –15 NO –6 –7
007 008
–20
1617- 1
–8
11617-
0.5 5 10 15 20 25 30 35 40 0.1 1 10 100 FREQUENCY (GHz) FREQUENCY (MHz)
Figure 4. Input Return Loss (S11) vs. Input Frequency with Figure 7. Envelope Bandwidth of VOUT vs. Frequency at PIN = −10 dBm and Input Connector and PCB Trace Embedded Modulation Depth = 10% (See Figure 36 in the Measurement Setups Section)
4 10 4 10 CALIBRATION AT CALIBRATION AT –26dBm, –14dBm, AND +5dBm –26dBm, –14dBm, AND +5dBm 3 3 2 1 2 1 E (V) 1 E (V) 1 G B) G B) A d A d LT LT R ( R ( O 0 0.1 O 0 0.1 T V RRO T V RRO U E U E –1 –1 TP TP –55°C –55°C OU –40°C OU –40°C –2 +25°C 0.01 –2 +25°C 0.01 +85°C +85°C +125°C +125°C –3 –3 –4 0.001 –4 0.001 –30 –25 –20 –15 –10 –5 0 5 10 15 20
009
012
P P
1617-
IN (dBm)
1617- 1
IN (dBm)
1 Figure 5. Conformance Error and Output Voltage (VOUT) vs. Figure 8. Distribution of Conformance Error with Respect to Output Voltage (VOUT) RF Input Power (PIN) for Various Temperatures at 0.5 GHz at 25°C vs. RF Input Power (PIN) for Various Temperatures at 0.5 GHz Rev. B | Page 9 of 22 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MEASUREMENT SETUPS THEORY OF OPERATION BASIC CONNECTIONS PCB LAYOUT RECOMMENDATIONS SYSTEM CALIBRATION AND ERROR CALCULATION EFFECT OF A CAPACITAVE LOAD ON RISE TIME AND FALL TIME EVALUATION BOARD EVALUATION BOARD ASSEMBLY DRAWINGS OUTLINE DIMENSIONS ORDERING GUIDE
