Datasheet HMC1120 (Analog Devices) - 6
ОписаниеRMS Power Detector & Envelope Tracker, DC - 3.9 GHz
Страниц / Страница29 / 6 — HMC1120LP4E. RMS POWER DETECTOR &. ENVELOPE TRACKER, DC - 3.9 GHz
Формат / Размер файлаPDF / 7.1 Мб
HMC1120LP4E RMS POWER DETECTOR & ENVELOPE TRACKER, DC - 3.9 GHz
HMC1120LP4E
v00.0814
RMS POWER DETECTOR & ENVELOPE TRACKER, DC - 3.9 GHz Table 2. Electrical Specifications ii, T = +25 °C, Vcc = 3.3V, A SCi4 = SCi3 = SCi2 = SCi1 = 3.3V, Unless Otherwise Noted Parameter Conditions Min Typ. Max Units
T
Single-Ended Input Configuration
M Input Network Return Loss up to 3.9 GHz > 12 dB S Input Resistance between INP and INN Between pins 3 and 4 100 Ω - Input Voltage Range AC Coupled Peak Voltage at INP- 1 V
RMSOUT Output
RS Output Voltage Range 0.32 to 2.7 V O Source/Sink Current Compliance RMSOUT held at VCC/2 +8 / -8 mA T Output Slew Rate (rise / fall) Sci4=Sci3=Sci2=Sci1=0V, Cofs=1nF 10.4 / 3.1 106 V/s C
ETOUT Output
E Modulation Bandwidth 150 MHz T Output Voltage Range 0.95 to 1.65 V E Source/Sink Current Compliance 8 / -3.9 mA Output Slew Rate (rise / fall) 210 / 242 106 V/s D %1 voltage drop from last peak, R Peak Hold Time 154 μs no external capacitor is connected E
VSET Input (Negative Feedback Terminal)
W For control applications with nominal Input Voltage Range 0.13 to 2.7 V slope/intercept settings O Input Resistance 5 MΩ P
SCI1-4 Inputs, EN Logic Input (Power Down Control)
Input High Voltage 0.7xVCC V Input Low Voltage 0.3xVCC V Input High Current 1 μA Input Low Current 1 μA Input Capacitance 0.5 pf
Power Supply
Supply Voltage 3.15 3.3 3.45 V EN = VCC, ETDISABLE = GND 77 82 90 mA Supply Current with no input power EN = VCC, ETDISABLE = VCC 62 mA Supply Current with 0 dBm 84 87 100 mA Standby Mode Supply Current EN = GND, ETDISABLE = VCC 7 9 12 mA For price, delivery and to place orders: Hittite Microwave Corporation, 2 Elizabeth Drive, Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order On-line at www.hittite.com
3
Application Support: Phone: 978-250-3343 or apps@hittite.com Document Outline Typical Applications Features Functional Diagram General Description Typical Performance Characteristics Electrical Specifications RMSOUT Error vs. Pin with Different Modulations @ 1900 MHz RMSOUT & Error vs. Pin @ 500 MHz RMSOUT & Error vs. Pin @ 900 MHz RMSOUT & Error vs. Pin @ 1900 MHz RMSOUT & Error vs. Pin @ 2200 MHz RMSOUT & Error vs. Pin @ 2700 MHz RMSOUT & Error vs. Pin @ 3500 MHz RMSOUT Intercept vs. Frequency RMSOUT Slope vs. Frequency RMSOUT vs. Pin with WCDMA 4 Carrier @ +25 °C RMSOUT Error vs. Pin with WCDMA 4 Carrier @ +25 °C RMSOUT Error vs. Pin with WCDMA 4 Carrier @ +85 °C wrt +25 °C Response RMSOUT vs. Pin with CW @ +25 °C RMSOUT Error vs. Pin with CW @ +25 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & +25 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ +25 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & +85 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ +85 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & -40 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ -40 °C RMSOUT Output Response with SCI = 0000 @ 1900 MHz RMSOUT Output Response with SCI = 1100 @ 1900 MHz Typical Supply Current vs. Pin, Vcc = 3.3V Input Return Loss vs. Frequency Output Ripple & Rise/Fall Time vs. Integration Setting [Sci4,Sci3,Sci2,Sci1] in Decimal ETOUT vs. Vin with CW @ 900 MHz ETOUT & ETOUT Error vs. Pin with CW @ 900 MHz ETOUT vs. Vin with CW @ 1900 MHz ETOUT & ETOUT Error vs. Pin with CW @ 1900 MHz ETOUT vs. Pin with CW @ 2200 MHz ETOUT & ETOUT Error vs. Pin with CW @ 2200 MHz ETOUT vs. Pin with CW @ 2700 MHz ETOUT & ETOUT Error vs. Pin with CW @ 2700 MHz ETOUT vs. Pin with CW @ 3500 MHz ETOUT & ETOUT Error vs. Pin with CW @ 3500 MHz ETOUT & ETOUT Error vs. Pin with CW @ 3900 MHz ETOUT vs. Pin with CW @ 3900 MHz ETOUT Intercept vs. Frequency with CW ETOUT Slope vs. Frequency with CW Absolute Maximum Ratings Outline Drawing Package Information Pin Descriptions Evaluation PCB Evaluation Order Information List of Materials for Evaluation PCB Application Circuit Application Information Principle of Operation Configuration For The Typical Application Broadband Single-Ended Input Interface Envelope Detector Output RMS Output Interface and Transient Response LOG-Slope and Intercept DC Offset Compensation Loop Standby Mode Modulation Performance - Crest factor performance System Calibration Layout Considerations Definitions
