Datasheet HMC7447 (Analog Devices) - 7
ОписаниеE-Band Detector, 71 - 86 GHz
Страниц / Страница10 / 7 — HMC7447. E-BAND DETECTOR. 71 - 86 GHz. Pin Descriptions. Assembly Diagram
Формат / Размер файлаPDF / 439 Кб
HMC7447 E-BAND DETECTOR 71 - 86 GHz Pin Descriptions Assembly Diagram
HMC7447
v00.0913
Pad Number Function Description Pad Schematic 1 RF IN IP These ports are matched to 50 Ohms. H 2 RF OUT DC voltage representing RF output power rectified by 3 Vdet diode which is biased through an external resistor. See R - C application circuit. O T DC voltage of diode biased through external resistor used 4 Vref for temperature compensation of Vdet. See application C circuit. E T E Die Bottom GND Die bottom must be connected to RF/DC ground. R D E
Assembly Diagram
W O P Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
