Datasheet ADL5505 (Analog Devices) - 10
Описание450 MHz TO 6000 MHz TruPwr™ Detector
Страниц / Страница22 / 10 — ADL5505. TYPICAL PERFORMANCE CHARACTERISTICS. 450MHz. 900MHz. 1900MHz. …
ВерсияA
ADL5505. TYPICAL PERFORMANCE CHARACTERISTICS. 450MHz. 900MHz. 1900MHz. 2600MHz. 3500MHz. 5000MHz. 6000MHz. (V). R (. T U. RRO. 0.1. 0.01. –25. –20. –15
ADL5505 TYPICAL PERFORMANCE CHARACTERISTICS 450MHz 900MHz 1900MHz 2600MHz 3500MHz 5000MHz 6000MHz (V) R ( T U RRO 0.1 0.01 –25 –20 –15
АЦП азиатских производителей
TA = 25°C; VS = 3.0 V; COUT = open; light condition ≤ 600 lux; 75 Ω input termination resistor; colors: black = +25°C, blue = −40°C, red = +85°C; unless otherwise noted.
10 3 450MHz 450MHz 900MHz 900MHz 1900MHz 1900MHz 2600MHz 2 2600MHz 3500MHz 3500MHz 5000MHz 5000MHz 6000MHz 6000MHz 1 1 B) (V) d T R ( PU 0 T U RRO O E 0.1 –1 –2 0.01 –3 –25 –20 –15 –10 –5 0 5 10 15
004
007
INPUT (dBm) INPUT (dBm)
05799- 05799- Figure 4. Output vs. Input Level; Frequencies = 450 MHz, 900 MHz, 1900 MHz, Figure 7. Linearity Error vs. Input Level; Frequencies = 450 MHz, 900 MHz, 2600 MHz, 3500 MHz, 5000 MHz, 6000 MHz; Supply = 3.0 V 1900 MHz, 2600 MHz, 3500 MHz, 5000 MHz, 6000 MHz; Supply = 3.0 V
2.0 10 450MHz 2.5V 900MHz 1.8 2.7V 1900MHz 3.0V 2600MHz 1.6 3.3V 3500MHz 5000MHz 1.4 6000MHz 1 1.2 (V) (V) T T 1.0 PU PU T T U U O 0.8 O 0.1 0.6 0.4 0.2 0 0.01 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0
005
008
INPUT (V rms) INPUT (dBm)
05799- 05799- Figure 5. Output vs. Input Level (Linear Scale); Frequencies = 450 MHz, 900 MHz, Figure 8. Output vs. Input Level; Supplies = 1900 MHz, 2600 MHz, 3500 MHz, 5000 MHz, 6000 MHz; Supply = 3.0 V 2.5 V, 2.7 V, 3.0 V, and 3.3 V; Frequency = 900 MHz
2.5 100 700 1.4 600 1.2 2.0 80 ) ) F rms) 500 1.0 p ( /V V V) 1.5 60 N ( (m ANCE 400 0.8 ANCE AI T T EPT IS SHUNT CAPACITANCE N G C S ACI P IO 300 0.6 1.0 40 ER RE T RS CA E IN SHUNT RESISTANCE NV HUNT 200 0.4 S HUNT S CO 0.5 20 100 0.2 0 0 0 0 0 1 2 3 4 5 6
006
0.5 1.0 1.5 2.0 2.5 3.0
009
FREQUENCY (GHz) FREQUENCY (GHz)
05799- 05799- Figure 6. Conversion Gain and Intercept vs. Frequency; Supply = 3.0 V; Figure 9. Input Impedance vs. Frequency; Supply = 3.0 V Temperatures = −40°C, +25°C, and +85°C Rev. A | Page 8 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description RMS Circuit Description and Filtering Filtering Output Buffer Applications Information Basic Connections RF Input Interfacing Resistive Tap RF Input Multiple RF Inputs Linearity Output Swing Output Offset Output Drive Capability and Buffering Selecting the Output Low-Pass Filter Power Consumption Device Calibration and Error Calculation Calibration for Improved Accuracy Drift Over a Reduced Temperature Range Device Handling Land Pattern and Soldering Information Evaluation Board Outline Dimensions Ordering Guide
