Datasheet HMC1010LP4E (Analog Devices) - 8
ОписаниеRMS Power Detector SMT, DC - 3.9 GHz
Страниц / Страница25 / 8 — HMC1010LP4E. RMS POWER DETECTOR. DC - 3.9 GHz. Reading Error for WCDMA 4 …
Формат / Размер файлаPDF / 2.9 Мб
HMC1010LP4E. RMS POWER DETECTOR. DC - 3.9 GHz. Reading Error for WCDMA 4 Carrier wrt
HMC1010LP4E RMS POWER DETECTOR DC - 3.9 GHz Reading Error for WCDMA 4 Carrier wrt
HMC1010LP4E
v03.0511
RMS POWER DETECTOR DC - 3.9 GHz Reading Error for WCDMA 4 Carrier wrt RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier CW Response @ +85 °C [1] (TM1-64 DPCH) @ 1900 MHz & -40 °C [1]
1 3 0.8 2.5 0.6 0.4 2 CW WCDMA 0.2 (V) (dB) 0 1.5 -0.2 ERROR 100 MHz RMSOUT 1 -0.4 900 MHz 1900 MHz -0.6 2200 MHz 11 2700 MHz 0.5 -0.8 3500 MHz 3900 MHz -1 0 -70 -60 -50 -40 -30 -20 -10 0 10 -70 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm) t M
Reading Error for WCDMA 4 Carrier wrt Output Response
s
CW Response @ -40 °C [1] with SCI = 0000 @ 1900 MHz
- 1 3 25 0.8 rs RMSOUT 2.5 20 0.6 RF o 0.4 ENABLE t 2 -20 dBm 15 0 dBm 0.2 (V) c (dB) 0 1.5 10 VOLTAGE e -0.2 t ERROR 100 MHz RMSOUT 1 5 -0.4 900 MHz e 1900 MHz RF RF RF (V) -0.6 2200 MHz OFF ON OFF RF ENABLE 2700 MHz 0.5 0 D -0.8 3500 MHz 3900 MHz r -1 0 -5 -70 -60 -50 -40 -30 -20 -10 0 10 e -2 0 2 4 6 8 10 12 14 16 18 INPUT POWER (dBm) TIME (μs) w o P
Typical Supply Current vs. Pin, Vcc = 5V
60 55 (mA) 50 CURRENT 45 +25 C +85 C -40 C SUPPLY 40 35-70 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) [1] Data was taken at sci4=sci1=0V, sci3=sci2=5V, shortest integration time is for scI=0000, allowed longest integration time is for scI=1100 Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
11 - 7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
