Datasheet HMC713LP3E (Analog Devices) - 9
Описание54 dB, LOGARITHMIC DETECTOR / CONTROLLER, 50 - 8000 MHz
Страниц / Страница12 / 9 — HMC713LP3E. 54 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 50 - 8000 MHz. Pin …
Формат / Размер файлаPDF / 918 Кб
HMC713LP3E. 54 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 50 - 8000 MHz. Pin Descriptions (Continued). 11 - 9
HMC713LP3E 54 dB, LOGARITHMIC DETECTOR / CONTROLLER, 50 - 8000 MHz Pin Descriptions (Continued) 11 - 9
11 предложений от 9 поставщиков
Усилитель IC и модуль RF, RF Detector 50MHz to 8000MHz 12dBm 16Pin QFN EP T/R
HMC713LP3ETR
от 275 ₽
727GS
HMC713LP3ETR
294 ₽
ЗУМ-СМД
HMC713LP3ETR
IC Home
HMC713LP3ETR
HMC713LP3E
v01.1009
Pin Number Function Description Interface schematic Logarithmic output that converts the input power to a 13 oUtP Dc level in controller mode. output voltage increases with increasing amplitude 11 t M Inverted logarithmic output. 14 oUtN s oUtN= 2.55 - 2 x oUtP s - r o t c e Bias supply. connect supply voltage 15, 16 Vcc t to these pins with appropriate filtering. e r D e w o P Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m
11 - 9
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
