Datasheet AD8362 (Analog Devices) - 22
Описание50 Hz to 3.8 GHz 65d dB TruPwr™ Detector
Страниц / Страница34 / 22 — Data Sheet. AD8362. 3.00. 3.0. 2.8GHz. 2.75. 2.5. 3.45GHz. 3.65GHz. 2.50. …
ВерсияF
Data Sheet. AD8362. 3.00. 3.0. 2.8GHz. 2.75. 2.5. 3.45GHz. 3.65GHz. 2.50. 2.0. 2.25. 1.5. 2.00. 1.0. 1.75. 0.5. dB). T (V). R (. U 1.50. VO 1.25. –0.5. 4.0. ERRO. 450MHz
Data Sheet AD8362 3.00 3.0 2.8GHz 2.75 2.5 3.45GHz 3.65GHz 2.50 2.0 2.25 1.5 2.00 1.0 1.75 0.5 dB) T (V) R ( U 1.50 VO 1.25 –0.5 4.0 ERRO 450MHz
18 предложений от 13 поставщиков
Модуль RF, IC и деталь , RF Detector 5e-05MHz to 3800MHz 15dBm 16Pin TSSOP T/R
AD8362ARU-REEL7
63 ₽
Зенер
Россия и страны ТС
AD8362ARU-REEL7
от 1 019 ₽
AD8362ARU-REEL7
1 522 ₽
Эиком
AD8362ARU-REEL7
1 960 ₽
link to page 22 link to page 22 link to page 22 link to page 23
Data Sheet AD8362
An external 100 Ω shunt resistor combines with the internal
3.00 3.0 2.8GHz
100 Ω single-ended input impedance to provide a broadband
50 Ω match. The unused input (in this case, INLO) is ac-coupled
2.50 2.0
to ground. Figure 49 shows the transfer function of the AD8362
2.25 1.5
at various frequencies when the RF input is driven single-
2.00 1.0
ended. The results show that transfer function linearity at the
top end of the range is degraded by the single-ended drive.
U 1.50 0 VO 1.25 –0.5 4.0 2.0 ERRO 450MHz 1.00 –1.0 1900MHz 3.5 2500MHz 1.5 0.75 –1.5 900MHz 2140MHz 0.50 –2.0 3.0 1.0 0.25 –2.5 2.5 0.5 0 –3.0 dB) –60 –55 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 15
051
T (V) R ( U 2.0 0 INPUT AMPLITUDE (dBm)
02923-
VO ERRO
Figure 51. Transfer Function at Various Frequencies ≥2.7 GHz when
1.5 –0.5
the RF Input is Driven Single-Ended
1.0 –1.0 OPERATION AT LOW FREQUENCIES 0.5 –1.5
In conventional rms-to-dc converters based on junction tech-
0 –2.0
niques, the effective signal bandwidth is proportional to the
049 signal amplitude. In contrast, the 3.5 GHz VGA bandwidth in
PIN (dBm)
02923- the AD8362 is independent of its gain. Because this amplifier is Figure 49. Transfer Function at Various Frequencies when the internally dc-coupled, the system is also used as a high accuracy RF Input is Driven Single-Ended rms voltmeter at low frequencies, retaining its temperature-
AD8362
stable, decibel-scaled output (for example, in seismic, audio,
1 COMM ACOM 16 0.01µF
and sonar instrumentation).
2 CHPF VREF 15 1nF 3 DECL VTGT 14 RF INPUT
While the AD8362 can be operated at arbitrarily low frequencies,
2.7nH 4 INHI VPOS 13
an ac-coupled input interface must be maintained. In such cases,
1nF 1nF 5 INLO VOUT 12 4.7nH
the input coupling capacitors should be large enough so that the
1nF 6 DECL VSET 11
lowest frequency components of the signal to be included in the
7 PWDN ACOM 10
measurement are minimal y attenuated. For example, for a 3 dB
8 COMM CLPF 9
reduction at 1.5 kHz, capacitances of 1 µF are needed because the 050 input resistance is 100 Ω at each input pin (200 Ω differential y), 02923- Figure 50. Input Matching for Operation at Frequencies ≥2.7 GHz and the calculation is 1/(2π × 1.5 kΩ × 100) = 1 μF. In addition, to lower the high-pass corner frequency of the VGA, a large capaci- For operation at frequencies ≥2.7 GHz, some additional tor must be connected between the CHPF pin and ground (see components are required to match the AD8362 input to 50 Ω the Choosing a Value for CHPF section). (see Figure 50). As the operating frequency increases, there is also corresponding shifting in the operating power range (see More information on the operation of the AD8362 and other Figure 51). RF power detectors at low frequency is available in AN-691 Application Note, Operation of RF Detector Products at Low Frequency. Rev. F | Page 21 of 33 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS CHARACTERIZATION SETUP EQUIPMENT ANALYSIS CIRCUIT DESCRIPTION SQUARE LAW DETECTION VOLTAGE vs. POWER CALIBRATION OFFSET ELIMINATION TIME-DOMAIN RESPONSE OF THE CLOSED LOOP OPERATION IN RF MEASUREMENT MODE BASIC CONNECTIONS DEVICE DISABLE RECOMMENDED INPUT COUPLING Choosing Input Coupling Capacitors Single-Ended Input Drive OPERATION AT LOW FREQUENCIES CHOOSING A VALUE FOR CHPF CHOOSING A VALUE FOR CLPF ADJUSTING VTGT TO ACCOMMODATE SIGNALS WITH VERY HIGH CREST FACTORS ALTERING THE SLOPE TEMPERATURE COMPENSATION AND REDUCTION OF TRANSFER FUNCTION RIPPLE TEMPERATURE COMPENSATION AT VARIOUS WiMAX FREQUENCIES UP TO 3.8 GHz OPERATION IN CONTROLLER MODE RMS VOLTMETER WITH 90 dB DYNAMIC RANGE AD8362 EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
