Datasheet AD8361 (Analog Devices) - 2
ОписаниеLF to 2.5 GHz TruPwr™ Detector
Страниц / Страница23 / 2 — AD8361* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
ВерсияF
Формат / Размер файлаPDF / 611 Кб
AD8361* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8361* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS REFERENCE MATERIALS
Радиочастотный детектор , RF Detector IC Cellular, CDMA, W-CDMA 100MHz ~ 2.5GHz ~ 700mV ±0.25dB 8-TSSOP, 8-MSOP (0.118", 3mm Width)...
AD8361ARM-REEL7
855 ₽
AD8361ARM-REEL7
1 203 ₽
727GS
AD8361ARM-REEL7
Рутоника
AD8361ARM-REEL7
View a parametric search of comparable parts.
Product Selection Guide
• RF Source Booklet
EVALUATION KITS Technical Articles
• AD8361 Evaluation Board • Design a Logamp RF Pulse Detector • Log Amps and Directional Couplers Enable VSWR
DOCUMENTATION
Detection
Application Notes
• Measurement and Control of RF Power, Part I • AN-1040: RF Power Calibration Improves Performance of • Measurement and Control of RF Power, Part II Wireless Transmitters • Measurement and Control of RF Power, Part III • AN-653: Improving Temperature, Stability, and Linearity • Measuring the RF Power in CDMA2000 and W-CDMA High of High Dynamic Range RMS RF Power Detectors Power Amplifiers (HPAs) • AN-691: Operation of RF Detector Products at Low • Measuring VSWR and Gain in Wireless Systems Frequency
Tutorials Data Sheet
• Design and Operation of Automatic Gain Control Loops • AD8361: LF to 2.5 GHz TruPwr™ Detector Data Sheet for Receivers in Modern Communication Systems
TOOLS AND SIMULATIONS DESIGN RESOURCES
• ADIsimPLL™ • AD8361 Material Declaration • ADIsimRF • PCN-PDN Information • AD8361 S-Parameters • Quality And Reliability • Symbols and Footprints
DISCUSSIONS
View all AD8361 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION Filtering Offset APPLICATION INFORMATION Basic Connections Output Swing Dynamic Range Input Coupling and Matching Input Coupling Using a Series Resistor Selecting the Filter Capacitor Operation at Low Frequencies Power Consumption, Enable and Power-On Volts to dBm Conversion Output Drive Capability and Buffering OUTPUT REFERENCE TEMPERATURE DRIFT COMPENSATION Extended Frequency Characterization EVALUATION BOARD CHARACTERIZATION SETUPS Equipment Analysis OUTLINE DIMENSIONS ORDERING GUIDE
