Datasheet LTC6905 (Analog Devices) - 3
Описание17MHz to 170MHz Resistor Set SOT-23 Oscillator
Страниц / Страница12 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 175 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full specifi ed
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full specifi ed
27 предложений от 18 поставщиков
Silicon Oscillator - 17MHz to 170MHz CMOS Automotive 5-Pin TSOT-23 T/R / IC OSC SILICON PROG TSOT23-5
LTC6905IS5-96#TRPBF
69 ₽
SUV System
LTC6905IS5-100#TRPBF
Hi-Tech Circuit Group
TradeElectronics
LTC6905IS5-133#TRPBF
LTC6905
l
denotes the specifi cations which apply over the full specifi ed temperature range, otherwise specifi cations are at TA = 25°C or as noted. V+ = 2.7V to 5.5V, RL = 15k, CL = 5pF, Pin 4 = V+ unless otherwise noted. All voltages are with respect to GND. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Δf Frequency Accuracy (Notes 2, 9) V+ = 2.7V, 17.225MHz < f < 170MHz ±0.5 ±1.4 % V+ = 5V, 17.225MHz < f < 170MHz ±2.2 % LTC6905CS5 V+ = 2.7V, 17.225MHz < f < 170MHz l ±1.7 % V+ = 5V, 17.225MHz < f < 170MHz l ±2.5 % LTC6905MPS5 (25°C ≤ T ≤ 125°C), LTC6905HS5 (25°C ≤ T ≤ 125°C), LTC6905IS5 (25°C ≤ T ≤ 85°C) V+ = 2.7V, 17.225MHz < f < 170MHz ±1.9 % V+ = 5V, 17.225MHz < f < 170MHz ±2.9 % LTC6905MPS5 (–55°C < T < 125°C), LTC6905HS5 (–40°C ≤ T ≤ 125°C), LTC6905IS5 (–40°C ≤ T ≤ 85°C) V+ = 2.7V, 17.225MHz < f < 170MHz l ±3.5 % V+ = 5V, 17.225MHz < f < 170MHz l ±3.5 % Δf Frequency Accuracy (Notes 2, 9) RSET Frequency-Setting Resistor Range 10 25 kΩ fMAX Maximum Frequency Pin 4 = V+, N = 1 170 MHz fMIN Minimum Frequency Pin 4 = 0V, N = 4 17.225 MHz Δf/ΔT Freq Drift Over Temp (Note 2) RSET = 10k l ±20 ppm/°C Δf/ΔV Freq Drift Over Supply (Notes 2, 9) V+ = 2.7V to 5.5V, RSET = 10k l 0.5 %/V Peak-to-Peak Timing Jitter (Note 3) 0.8 % Long-Term Stability of Output Frequency 300 ppm/√kHr Duty Cycle l 47.5 50 52.5 % V+ Operating Supply Range l 2.7 5.5 V IS Power Supply Current RSET = 10k, N = 1, RL = ∞, V+ = 5.5V l 14 20 mA fOSC = 170MHz, CL = 5pF V+ = 2.7V l 7 12 mA RSET = 20k, N = 4, RL = ∞, V+ = 5.5V l 5 7 mA fOSC = 21.44MHz, CL = 5pF V+ = 2.7V l 3 5 mA VIH High Level DIV Input Voltage l V+ – 0.15 V VIL Low Level DIV Input Voltage l 0.2 V IDIV DIV Input Current (Note 4) Pin 4 = V+ V+ = 5.5V l 15 40 μA Pin 4 = 0V V+ = 5.5V –40 –11 μA VOH High Level Output Voltage (Note 4) V+ = 5.5V, Pin 4 = 0V IOH = –1mA l 5.25 5.45 V IOH = –4mA l 5.20 5.30 V V+ = 2.7V, Pin 4 = 0V IOH = –1mA l 2.5 2.6 V IOH = –4mA l 2.4 2.4 V 6905fd 3
