Datasheet LTC6906 (Analog Devices) - 2
ОписаниеMicropower, 10kHz to 1MHz Resistor Set Oscillator in SOT-23
Страниц / Страница14 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
Формат / Размер файлаPDF / 172 Кб
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
33 предложений от 16 поставщиков
Интегральные микросхемы Тактовые микросхемы - Программируемые таймеры и Генераторы
727GS
LTC6906HS6#TRMPBF
от 4.63 ₽
LTC6906HS6#TRMPBF
143 ₽
LTC6906HS6#TRMPBF
от 668 ₽
LTC6906HS6 TRMPBF
LTC6906
V+ .. –0.3V to 6V TOP VIEW DIV to GND ...–0.3V to (V+ + 0.3V) OUT 1 6 V+ SET to GND ...–0.3V to (V+ + 0.3V) GND 2 5 GRD GRD to GND ..–0.3V to (V+ + 0.3V) DIV 3 4 SET Operating Temperature Range (Note 7) S6 PACKAGE 6-LEAD PLASTIC TSOT-23 LTC6906C .. –40°C to 85°C TJMAX = 150°C, θJA = 230°C/W LTC6906I ... –40°C to 85°C LTC6906H .. –40°C to 125°C Specified Temperature Range (Note 7) LTC6906C .. 0°C to 70°C LTC6906I ... –40°C to 85°C LTC6906H .. –40°C to 125°C Storage Temperature Range .. –65°C to 150°C Lead Temperature (Soldering, 10 sec) ... 300°C
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC6906CS6#PBF LTC6906CS6#TRPBF LTBJN 6-Lead Plastic TSOT-23 0°C to 70°C LTC6906IS6#PBF LTC6906IS6#TRPBF LTBJN 6-Lead Plastic TSOT-23 –40°C to 85°C LTC6906HS6#PBF LTC6906HS6#TRPBF LTBJN 6-Lead Plastic TSOT-23 –40°C to 125°C
LEAD BASED FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC6906CS6 LTC6906CS6#TR LTBJN 6-Lead Plastic TSOT-23 0°C to 70°C LTC6906IS6 LTC6906IS6#TR LTBJN 6-Lead Plastic TSOT-23 –40°C to 85°C LTC6906HS6 LTC6906HS6#TR LTBJN 6-Lead Plastic TSOT-23 –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
ELECTRICAL CHARACTERISTICS The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Δf Frequency Accuracy (Notes 2, 3, 9) V+ = 2.7V to 3.6V 100kHz ≤ f ≤ 1MHz ±0.25 ±0.5 % 100kHz ≤ f ≤ 1MHz, LTC6906C l ±0.65 % 100kHz ≤ f ≤ 1MHz, LTC6906I l ±1.3 % f = 1MHz, LTC6906H l ±1.3 % f = 100kHz, LTC6906H l ±2.2 % V+ = 2.25V 100kHz ≤ f ≤ 1MHz ±0.25 ±0.7 % 100kHz ≤ f ≤ 1MHz, LTC6906C l ±0.85 % 100kHz ≤ f ≤ 1MHz, LTC6906I l ±1.3 % f = 1MHz, LTC6906H l ±1.3 % f = 100kHz, LTC6906H l ±2.2 % 6906fc 2
