Линейка продуктов KEEN SIDE
Datasheet ADA4077-2 (Analog Devices) - 4
Описание4 MHz, 7 nV/√Hz, Low Offset and Drift, High Precision Dual Amplifier
Страниц / Страница21 / 4 — STANDARD. 5962-14233. MICROCIRCUIT DRAWING
Формат / Размер файлаPDF / 350 Кб
STANDARD 5962-14233 MICROCIRCUIT DRAWING
45 предложений от 20 поставщиков
ADA4077-2ARMZ
от 72 ₽
ЧипСити
ADA4077-2ARMZ
81 ₽
Эиком
ADA4077-2ARMZ-R7
от 549 ₽
ADA4077-2ARMZ
1.5 Radiation features. Maximum total dose available (dose rate = 50 – 300 rads(Si)/s) : Device type 01 ... 100 krads(Si) 6/ Maximum total dose available (dose rate ≤ 10 mrads(Si)/s) : Device type 02 ... 50 krads(Si) 7/ Single Event Phenomenon (SEP): No Single Event latchup (SEL) occurs at Effective linear energy transfer (LET) (see 4.4.4.2): Device types 01, 02: .. ≤ 80 MeV-cm2/mg 8/ 2. APPLICABLE DOCUMENTS 2.1 Government specification, standards, and handbooks. The following specification, standards, and handbooks form a part of this drawing to the extent specified herein. Unless otherwise specified, the issues of these documents are those cited in the solicitation or contract. DEPARTMENT OF DEFENSE SPECIFICATION MIL-PRF-38535 - Integrated Circuits, Manufacturing, General Specification for. DEPARTMENT OF DEFENSE STANDARDS MIL-STD-883 - Test Method Standard Microcircuits. MIL-STD-1835 - Interface Standard Electronic Component Case Outlines. DEPARTMENT OF DEFENSE HANDBOOKS MIL-HDBK-103 - List of Standard Microcircuit Drawings. MIL-HDBK-780 - Standard Microcircuit Drawings. (Copies of these documents are available online at http://quicksearch.dla.mil/ or from the Standardization Document Order Desk, 700 Robbins Avenue, Building 4D, Philadelphia, PA 19111-5094.) 2.2 Non-Government publications. The following document(s) form a part of this document to the extent specified herein. Unless otherwise specified, the issues of the documents are the issues of the documents cited in the solicitation or contract. ASTM INTERNATIONAL (ASTM) ASTM F1192 - Standard Guide for the Measurement of Single Event Phenomena (SEP) Induced by Heavy Ion Irradiation of Semiconductor Devices. (Copies of these documents are available online at http://www.astm.org or from ASTM International, 100 Barr Harbor Drive, P.O. Box C700, West Conshohocken, PA, 19428-2959). 2.2 Order of precedence. In the event of a conflict between the text of this drawing and the references cited herein, the text of this drawing takes precedence. Nothing in this document, however, supersedes applicable laws and regulations unless a specific exemption has been obtained. ________ 6/ Device type 01 may be dose rate sensitive in a space environment and may demonstrate enhanced low dose rate effects. Radiation end point limits for the noted parameters are guaranteed only for the conditions specified in MIL-STD-883, method 1019, condition A. 7/ Device type 02 is irradiated at low dose rate and radiation end point limits for the noted parameters are guaranteed for the conditions specified in MIL-STD-883, method 1019, condition D. 8/ Limits are characterized at initial qualification and after any design or process changes that may affect the SEP characteristics, but are not production lot tested unless specified by the customer through the purchase order or contract. For more information on single event effect (SEE) test results, customers are requested to contact the manufacturer.
STANDARD
SIZE
5962-14233 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 A 4 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
