Datasheet ADA4077-2-EP (Analog Devices) - 3
Описание4 MHz, 7 nV/√Hz, Low Offset and Drift, High Precision Amplifier
Страниц / Страница16 / 3 — Enhanced Product. ADA4077-2-EP. SPECIFICATIONS ELECTRICAL …
Формат / Размер файлаPDF / 547 Кб
Enhanced Product. ADA4077-2-EP. SPECIFICATIONS ELECTRICAL CHARACTERISTICS, ±5 V. Table 1. Parameter. Symbol
Enhanced Product ADA4077-2-EP SPECIFICATIONS ELECTRICAL CHARACTERISTICS, ±5 V Table 1 Parameter Symbol
6 предложений от 6 поставщиков
Микросхема Операционный усилитель, Op Amp Dual GP ±15V 8Pin MSOP T/R
ADA4077-2TRMZ-EPR7
723 ₽
ADA4077-2TRMZ-EPR7
762 ₽
ADA4077-2TRMZ-EPR7
912 ₽
ADA4077-2TRMZ-EPR7
VSY = ±5.0 V, VCM = 0 V, TA = 25°C, unless otherwise noted.
Table 1. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS 50 90 µV −55°C < TA < +125°C 220 µV Offset Voltage Drift ΔVOS/ΔT −55°C < TA < +125°C 0.5 1.2 µV/°C Input Bias Current IB −1 −0.4 +1 nA −55°C < TA < +125°C −1.5 +1.5 nA Input Offset Current IOS −0.5 +0.1 +0.5 nA −55°C < TA < +125°C −1.0 +1.0 nA Input Voltage Range −3.8 +3 V Common-Mode Rejection Ratio CMRR VCM = −3.8 V to +3 V 122 140 dB VCM = −3.8 V to +3 V, −55°C < TA < +85°C 120 dB VCM = −3.8 V to +2.8 V, 85°C < TA < 125°C 120 dB Large Signal Voltage Gain AV RL = 2 kΩ, VO = −3.0 V to +3.0 V 121 130 dB −55°C < TA < +125°C 120 dB Input Capacitance CINCM Common mode 5 pF Input Resistance RIN Common mode 70 GΩ OUTPUT CHARACTERISTICS Output Voltage High VOH IL = 1 mA 3.8 V −55°C < TA < +125°C 3.7 V Output Voltage Low VOL IL = 1 mA −3.8 V −55°C < TA < +125°C −3.7 V Output Current IOUT VDROPOUT < 1.6 V ±10 mA Short-Circuit Current ISC TA = 25°C 22 mA Closed-Loop Output Impedance ZOUT f = 1 kHz, AV = +1 0.05 Ω POWER SUPPLY Power Supply Rejection Ratio PSRR VS = ±2.5 V to ±18 V 123 128 dB −55°C < TA < +125°C 120 dB Supply Current per Amplifier ISY VO = 0 V 400 450 µA −55°C < TA < +125°C 650 µA DYNAMIC PERFORMANCE Slew Rate SR RL = 2 kΩ 1.2 V/µs Settling Time to 0.1% tS VIN = 1 V step, RL = 2 kΩ, AV = −1 3 µs Gain Bandwidth Product GBP VIN = 10 mV p-p, RL = 2 kΩ, AV = +100 3.9 MHz Unity-Gain Crossover UGC VIN = 10 mV p-p, RL = 2 kΩ, AV = +1 3.9 MHz −3 dB Closed-Loop Bandwidth −3 dB AV = +1, VIN = 10 mV p-p, RL = 2 kΩ 5.9 MHz Phase Margin ΦM VIN = 10 mV p-p, RL = 2 kΩ, AV = +1 55 Degrees Total Harmonic Distortion Plus Noise THD + N VIN = 1 V rms, AV = +1, RL = 2 kΩ, 0.004 % f = 1 kHz NOISE PERFORMANCE Voltage Noise en p-p 0.1 Hz to 10 Hz 0.25 µV p-p Voltage Noise Density en f = 1 Hz 13 nV/√Hz f = 100 Hz 7 nV/√Hz f = 1000 Hz 6.9 nV/√Hz Current Noise Density in f = 1 kHz 0.2 pA/√Hz MULTIPLE AMPLIFIERS CHANNEL SEPARATION CS f = 1 kHz, RL = 10 kΩ −125 dB Rev. 0 | Page 3 of 16 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS, ±5 V ELECTRICAL CHARACTERISTICS, ±15 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
