Datasheet ADA4897-2 (Analog Devices) - 10
Описание1 nV/√Hz, Low Power Operational Amplifier
Страниц / Страница22 / 10 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/13614
Формат / Размер файлаPDF / 280 Кб
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/13614
32 предложений от 14 поставщиков
Рутоника
ADA4897-1SRJZ-EPR7
428 ₽
ADA4897-1SRJZ-EPR7
1 027 ₽
727GS
ADA4897-1SRJZ-EPR7
ADA4897-1SRJZ-EPR7
TABLE I. Electrical performance characteristics – Continued. 1/ 2/ Test Symbol Conditions 2/ Temperature, Device Limits Unit V type S = +5 V, G = +1, TA R L = 1 kΩ to midsupply, Min Max unless otherwise specified DC performance section. Input offset voltage VIO +25°C 01, 02 -500 +500 µV -30 typical Input offset voltage drift ∆VIO +25°C 01, 02 0.2 typical µV / °C Input bias current IIB +25°C 01, 02 -17 -4 µA -11 typical Input bias current drift ∆IIB +25°C 01, 02 3 typical nA / °C Input bias offset current IIBO +25°C 01, 02 -0.6 +0.6 µA -0.02 typical Open loop gain AOL VOUT = 0.5 V to 4.5 V +25°C 01, 02 97 dB 110 typical Input characteristics section. Input resistance, RIN +25°C 01, 02 10 typical MΩ common mode Input resistance, RIN +25°C 01, 02 10 typical kΩ differential Input capacitance, CIN +25°C 01, 02 3 typical pF common mode Input capacitance, CIN +25°C 01, 02 11 typical pF differential Input common mode V V INR +25°C 01, 02 0.1 to 4.1 voltage range typical Common mode CMRR VCM = 1 V to 4 V +25°C 01, 02 -91 dB rejection ratio -118 typical See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/13614
REV PAGE 10 Document Outline DESCRIPTION REV REV PMIC N/A DLA LAND AND MARITIME TITLE SIZE A V62/13614 REV
