Линейка продуктов KEEN SIDE
Datasheet MCP6021, MCP601R, MCP602, MCP603, MCP604 (Microchip) - 19
ПроизводительMicrochip
ОписаниеThe MCP6021 operational amplifier (op amp) has a gain bandwidth product of 10 MHz with a low typical operating current of 1.0 mA and an offset voltage that is less than 0.5 mV
Страниц / Страница54 / 19 — MCP6021/1R/2/3/4. 4.6. MCP6021 and MCP6023 Reference Voltage. FIGURE …
MCP6021/1R/2/3/4. 4.6. MCP6021 and MCP6023 Reference Voltage. FIGURE 4-10:. 4.7. Supply Bypass. 4.8. Unused Operational Amplifiers
MCP6021/1R/2/3/4 4.6 MCP6021 and MCP6023 Reference Voltage FIGURE 4-10: 4.7 Supply Bypass 4.8 Unused Operational Amplifiers
Микросхема Операционный усилитель, IC OPAMP SNGL 2.5V 10MHz 8SOIC
MCP6023T-E/SN
29 ₽
MCP6023T-E/SN
73 ₽
MCP6023T-E/SN
MCP6023T-E/SN
link to page 19 link to page 19 link to page 19 link to page 19
RG RF V V The single operational amplifiers (MCP6021 and IN OUT MCP6023), not in the SOT-23-5 package, have an internal mid-supply reference voltage connected to the VREF pin (see Figure 4-8). The MCP6021 has CS inter- VREF nally tied to VSS, which always keeps the operational amplifier on and always provides a mid-supply refer- C ence. With the MCP6023, taking the CS pin high B conserves power by shutting down both the operational amplifier and the VREF circuitry. Taking the CS pin low turns on the operational amplifier and VREF circuitry.
FIGURE 4-10:
Inverting Gain Circuit Using VREF (MCP6021 and MCP6023 only). VDD If you don’t need the mid-supply reference, leave the VREF pin open. 50 k
4.7 Supply Bypass
VREF With this family of operational amplifiers, the power supply pin (VDD for single supply) should have a local 50 k bypass capacitor (i.e., 0.01 µF to 0.1 µF) within 2 mm for good, high-frequency performance. It also needs a bulk capacitor (i.e., 1 µF or larger) within 100 mm to CS provide large, slow currents. This bulk capacitor can be shared with nearby analog parts. 5 M
An unused operational amplifier in a quad package VSS (MCP6024) should be configured as shown in Figure 4-11. These circuits prevent the output from tog- (CS tied internally to V gling and causing crosstalk. Circuit A sets the opera- SS for MCP6021) tional amplifier at its minimum noise gain. The resistor
FIGURE 4-8:
Simplified Internal V divider produces any desired reference voltage within REF Circuit (MCP6021 and MCP6023 only). the output voltage range of the operational amplifier. The operational amplifier buffers that reference See Figure 4-9 for a non-inverting gain circuit using the voltage. Circuit B uses the minimum number of compo- internal mid-supply reference. The DC Blocking nents and operates as a comparator, but it may draw Capacitor (CB) also reduces noise by coupling the more current. operational amplifier input to the source.
¼ MCP6024 (A) ¼ MCP6024 (B)
RG RF VDD VDD V V DD R OUT 1 CB VREF V V REF IN R2
FIGURE 4-9:
Non-Inverting Gain Circuit Using V R REF (MCP6021 and MCP6023 only). 2 V = V + ---------- REF DD R + R To use the internal mid-supply reference for an 1 2 inverting gain circuit, connect the VREF pin to the non-inverting input, as shown in Figure 4-10. The
FIGURE 4-11:
Unused Operational capacitor, CB, helps reduce power supply noise on the Amplifiers. output.  2001-2017 Microchip Technology Inc. DS20001685E-page 19 Document Outline Features Applications Design Aids Typical Application Description Package Types 1.0 Electrical Characteristics Absolute Maximum Ratings† DC Electrical Characteristics AC Electrical Characteristics MCP6023 Chip Select (CS) Electrical Characteristics Temperature Characteristics FIGURE 1-1: Timing Diagram for the CS Pin on the MCP6023. 1.1 Test Circuits FIGURE 1-2: AC and DC Test Circuit for Most Non-Inverting Gain Conditions. FIGURE 1-3: AC and DC Test Circuit for Most Inverting Gain Conditions. 2.0 Typical Performance Curves FIGURE 2-1: Input Offset Voltage (Industrial Temperature Parts). FIGURE 2-2: Input Offset Voltage (Extended Temperature Parts). FIGURE 2-3: Input Offset Voltage vs. Common-Mode Input Voltage with VDD = 2.5V. FIGURE 2-4: Input Offset Voltage Drift (Industrial Temperature Parts). FIGURE 2-5: Input Offset Voltage Drift (Extended Temperature Parts). FIGURE 2-6: Input Offset Voltage vs. Common-Mode Input Voltage with VDD = 5.5V. FIGURE 2-7: Input Offset Voltage vs. Temperature. FIGURE 2-8: Input Noise Voltage Density vs. Frequency. FIGURE 2-9: CMRR, PSRR vs. Frequency. FIGURE 2-10: Input Offset Voltage vs. Output Voltage. FIGURE 2-11: Input Noise Voltage Density vs. Common-Mode Input Voltage. FIGURE 2-12: CMRR, PSRR vs. Temperature. FIGURE 2-13: Input Bias, Offset Currents vs. Common-Mode Input Voltage. FIGURE 2-14: Quiescent Current vs. Supply Voltage. FIGURE 2-15: Output Short-Circuit Current vs. Supply Voltage. FIGURE 2-16: Input Bias, Offset Currents vs. Temperature. FIGURE 2-17: Quiescent Current vs. Temperature. FIGURE 2-18: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-19: DC Open-Loop Gain vs. Load Resistance. FIGURE 2-20: Small Signal DC Open-Loop Gain vs. Output Voltage Headroom. FIGURE 2-21: Gain Bandwidth Product, Phase Margin vs. Temperature. FIGURE 2-22: DC Open-Loop Gain vs. Temperature. FIGURE 2-23: Gain Bandwidth Product, Phase Margin vs. Common-Mode Input Voltage. FIGURE 2-24: Gain Bandwidth Product, Phase Margin vs. Output Voltage. FIGURE 2-25: Slew Rate vs. Temperature. FIGURE 2-26: Total Harmonic Distortion plus Noise vs. Output Voltage with f = 1 kHz. FIGURE 2-27: The MCP6021/1R/2/3/4 Family Shows No Phase Reversal Under Overdrive. FIGURE 2-28: Maximum Output Voltage Swing vs. Frequency. FIGURE 2-29: Total Harmonic Distortion plus Noise vs. Output Voltage with f = 20 kHz. FIGURE 2-30: Channel-to-Channel Separation vs. Frequency (MCP6022 and MCP6024 only). FIGURE 2-31: Output Voltage Headroom vs. Output Current. FIGURE 2-32: Small Signal Non-Inverting Pulse Response. FIGURE 2-33: Large Signal Non-Inverting Pulse Response. FIGURE 2-34: Output Voltage Headroom vs. Temperature. FIGURE 2-35: Small Signal Inverting Pulse Response. FIGURE 2-36: Large Signal Inverting Pulse Response. FIGURE 2-37: VREF Accuracy vs. Supply Voltage (MCP6021 and MCP6023 only). FIGURE 2-38: Chip Select (CS) Hysteresis (MCP6023 only) with VDD = 2.5V. FIGURE 2-39: Chip Select (CS) to Amplifier Output Response Time (MCP6023 Only). FIGURE 2-40: VREF Accuracy vs. Temperature (MCP6021 and MCP6023 only). FIGURE 2-41: Chip Select (CS) Hysteresis (MCP6023 only) with VDD = 5.5V. FIGURE 2-42: Measured Input Current vs. Input Voltage (Below VSS) 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 3.1 Analog Outputs 3.2 Analog Inputs 3.3 Reference Voltage (VREF) MCP6021 and MCP6023 3.4 Chip Select Digital Input (CS) 3.5 Power Supply (VSS and VDD) 4.0 Applications Information 4.1 Rail-to-Rail Input 4.1.1 Phase Reversal 4.1.2 Input Voltage Limits FIGURE 4-1: Simplified Analog Input ESD Structures. FIGURE 4-2: Protecting the Analog Inputs. 4.1.3 Input Current Limits FIGURE 4-3: Protecting the Analog Inputs. 4.1.4 Normal Operation 4.2 Rail-to-Rail Output 4.3 Capacitive Loads FIGURE 4-4: Output Resistor, RISO, Stabilizes Large Capacitive Loads. FIGURE 4-5: Recommended RISO Values for Capacitive Loads. 4.4 Gain Peaking FIGURE 4-6: Non-Inverting Gain Circuit with Parasitic Capacitance. FIGURE 4-7: Non-Inverting Gain Circuit with Parasitic Capacitance. 4.5 MCP6023 Chip Select (CS) 4.6 MCP6021 and MCP6023 Reference Voltage FIGURE 4-8: Simplified Internal VREF Circuit (MCP6021 and MCP6023 only). FIGURE 4-9: Non-Inverting Gain Circuit Using VREF (MCP6021 and MCP6023 only). FIGURE 4-10: Inverting Gain Circuit Using VREF (MCP6021 and MCP6023 only). 4.7 Supply Bypass 4.8 Unused Operational Amplifiers FIGURE 4-11: Unused Operational Amplifiers. 4.9 PCB Surface Leakage FIGURE 4-12: Example Guard Ring Layout. 4.10 High-Speed PCB Layout 4.11 Typical Applications 4.11.1 A/D Converter Driver and Anti-Aliasing Filter FIGURE 4-13: A/D Converter Driver and Anti-Aliasing Filter with a 20 kHz Cutoff Frequency. 4.11.2 Optical Detector Amplifier FIGURE 4-14: Transimpedance Amplifier for an Optical Detector. 5.0 Design Aids 5.1 SPICE Macro Model 5.2 FilterLab® Software 5.3 MPLAB® Mindi™ Analog Simulator 5.4 Microchip Advanced Part Selector (MAPS) 5.5 Analog Demonstration and Evaluation Boards 5.6 Application Notes 6.0 Packaging Information 6.1 Package Marking Information Package Marking Information (Continued) Package Marking Information (Continued) APPENDIX A: Revision History Revision E (January 2017) Revision D (February 2009) Revision C (December 2005) Revision B (November 2003) Revision A (November 2001) Product Identification System Worldwide Sales and Service
