Datasheet ATtiny24A, ATtiny44A. Appendix A. Specification at 105°C (Microchip) - 4
ПроизводительMicrochip
Описание8-bit Microcontroller with 2K/4K Bytes In-System Programmable Flash
Страниц / Страница60 / 4 — Table 2-1. Symbol. Parameter. Condition. Min. Typ. Max. Units. 2.3. …
Формат / Размер файлаPDF / 3.3 Мб
Table 2-1. Symbol. Parameter. Condition. Min. Typ. Max. Units. 2.3. Speed. Figure 2-1. ATtiny24A/44A
Table 2-1 Symbol Parameter Condition Min Typ Max Units 2.3 Speed Figure 2-1 ATtiny24A/44A
32 предложений от 17 поставщиков
IC MCU 8BIT 4KB FLASH 20VQFN. AVR AVR® ATtiny Microcontroller IC 8-Bit 20MHz 4KB (2K x 16) FLASH 20-VQFN (3x3). Embedded...
ATTINY44A-MMHR
53 ₽
Рутоника
ATTINY44A-MMHR
64 ₽
ЧипСити
ATTINY44A-MMHR
Atmel
81 ₽
ATTINY44A-MMHR
link to page 4 link to page 4 link to page 4 link to page 4 link to page 22 link to page 22 link to page 22 link to page 23 link to page 23
Table 2-1.
DC Characteristics. T = -40°C to +105°C (Continued) A
(1)
Max Units
f = 1MHz, V = 2V 0.25 0.5 mA CC Supply Current, f = 4MHz, V = 3V 1.2 2 mA Active Mode (9) CC f = 8MHz, VCC = 5V 4.4 7 mA f = 1MHz, V = 2V 0.04 0.2 mA CC ICC Supply Current, f = 4MHz, V Idle Mode (9) CC = 3V 0.25 0.6 mA f = 8MHz, VCC = 5V 1.3 2 mA Supply Current, WDT enabled, V = 3V 4 20 µA CC Power-Down Mode (10) WDT disabled, VCC = 3V 0.2 10 µA Notes: 1. Typical values at 25°C. 2. “Min” means the lowest value where the pin is guaranteed to be read as high. 3. “Max” means the highest value where the pin is guaranteed to be read as low. 4. Not tested in production. 5. Although each I/O port can sink more than the test conditions (10 mA at V = 5V, 5 mA at V = 3V) under steady state CC CC conditions (non-transient), the sum of all IOL (for all ports) should not exceed 60 mA. If IOL exceeds the test conditions, VOL may exceed the related specification. Pins are not guaranteed to sink current greater than the listed test condition. 6. Although each I/O port can source more than the test conditions (10 mA at V = 5V, 5 mA at V = 3V) under steady state CC CC conditions (non-transient), the sum of all IOH (for all ports) should not exceed 60 mA. If IOH exceeds the test condition, VOH may exceed the related specification. Pins are not guaranteed to source current greater than the listed test condition. 7. The RESET pin must tolerate high voltages when entering and operating in programming modes and, as a consequence, has a weak drive strength as compared to regular I/O pins. See Figure 3-25, Figure 3-26, Figure 3-27, and Figure 3-28 (starting on page 22). 8. These are test limits, which account for leakage currents of the test environment. Actual device leakage currents are lower. 9. Values are with external clock using methods described in “Minimizing Power Consumption”. Power reduction is enabled (PRR = 0xFF) and there is no I/O drive. 10. BOD disabled.
2.3 Speed
The maximum operating frequency of the device depends on V As shown in Figure 2-1, the CC. relationship between maximum frequency and V is linear in the region 1.8V < V < 4.5V. CC CC
Figure 2-1.
Maximum Frequency vs. V . T = -40°C to +105°C CC A 20 MHz 4 MHz 1.8V 4.5V 5.5V
4 ATtiny24A/44A
8183D-Appendix A–AVR–08/11 Document Outline Appendix A – ATtiny24A/44A Specification at 105°C 1. Memories 1.1 EEPROM Data Memory 2. Electrical Characteristics 2.1 Absolute Maximum Ratings* 2.2 DC Characteristics 2.3 Speed 2.4 Clock Characteristics 2.4.1 Accuracy of Calibrated Internal Oscillator 2.5 System and Reset Characteristics 2.5.1 Power-On Reset 2.6 Analog Comparator Characteristics 2.7 ADC Characteristics 2.8 Serial Programming Characteristics 3. Typical Characteristics 3.1 ATtiny24A 3.1.1 Current Consumption in Active Mode 3.1.2 Current Consumption in Idle Mode 3.1.3 Current Consumption of Standby Supply 3.1.4 Current Consumption in Power-down Mode 3.1.5 Current Consumption of Peripheral Units 3.1.6 Pull-up Resistors 3.1.7 Output Driver Strength 3.1.8 Input Threshold and Hysteresis (for I/O Ports) 3.1.9 BOD and Bandgap 3.1.10 Analog Comparator Offset 3.1.11 Internal Oscillator Speed 3.2 ATtiny44A 3.2.1 Current Consumption in Active Mode 3.2.2 Current Consumption in Idle Mode 3.2.3 Current Consumption of Standby Supply 3.2.4 Current Consumption in Power-down Supply Mode 3.2.5 Current Consumption of Peripheral Units 3.2.6 Pull-up Resistors 3.2.7 Output Driver Strength 3.2.8 Input Threshold and Hysteresis (for I/O Ports) 3.2.9 BOD and Bandgap and Reset 3.2.10 Analog Comparator Offset 3.2.11 Internal Oscillator Speed 4. Ordering Information 4.1 ATtiny24A 4.2 ATtiny44A 5. Revision History
