Datasheet LM4040, LM4041 (Microchip) - 5
ПроизводительMicrochip
ОписаниеPrecision Micropower Shunt Voltage Reference
Страниц / Страница30 / 5 — LM4040/LM4041. LM4040-2.5 ELECTRICAL CHARACTERISTICS (Note 1) …
Версия04-26-2017
LM4040/LM4041. LM4040-2.5 ELECTRICAL CHARACTERISTICS (Note 1) (CONTINUED). Parameters. Sym. Min. Typ. Max. Units. Conditions. Note 1:
LM4040/LM4041 LM4040-2.5 ELECTRICAL CHARACTERISTICS (Note 1) (CONTINUED) Parameters Sym Min Typ Max Units Conditions Note 1:
36 предложений от 18 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Опорное напряжение
Рутоника
LM4041DYM3-ADJ-TR
19 ₽
LM4041DYM3-ADJ-TR
23 ₽
727GS
LM4041DYM3-ADJ-TR
от 14 764 ₽
SUV System
LM4041DYM3-ADJ-TR
TA = Operating Temperature Range, TA = TJ = –40°C to +85°C, unless noted.
Parameters Sym. Min. Typ. Max. Units Conditions
Reverse-Breakdown Voltage ∆VR/∆IR — 0.3 1.0 mV IRMIN ≤ IR ≤ 1 mA, Change with Operating TA = +25°C Current Change — — 1.2 IRMIN ≤ IR ≤ 1 mA — 2.5 8.0 1 mA ≤ IR ≤ 15 mA, TA = +25°C — — 10.0 1 mA ≤ IR ≤ 15 mA Reverse Dynamic Impedance ZR — 0.3 1.1 Ω IR = 1 mA, f = 120 Hz, IAC = 0.1 IR, TA = +25°C Wideband Noise eN — 35 — µVRMS IR = 100 µA, 10 Hz ≤ f ≤ 10 kHz Reverse-Breakdown Voltage ∆VR — 120 — ppm t = 1000 hrs., TA = +25°C Long-Term Stability ±0.1°C, IR = 100 µA
Note 1:
Specification for packaged product only.
2:
The boldface (overtemperature) limit for Reverse-Breakdown Voltage Tolerance is defined as the room temperature Reverse-Breakdown Voltage Tolerance ±[(∆VR/∆T)(65°C)(VR)]. ∆VR/∆T is the VR tempera- ture coefficient, 65°C is the temperature range from –40°C to the reference point of 25°C, and VR is the reverse-breakdown voltage. The total overtemperature tolerance for the different grades follows: a. C-grade: ±1.15% = ±0.5% ±100 ppm/°C × 65°C b. D-grade: ±1.98% = ±1.0% ±150 ppm/°C × 65°C Example: The C-grade LM4040-2.5 has an overtemperature Reverse-Breakdown Voltage tolerance of ±2.5 × 1.15% = ±29 mV.  2017 Microchip Technology Inc. DS20005757A-page 5 Document Outline 1.0 Electrical Characteristics 2.0 Typical Performance Curves 3.0 Pin Descriptions 4.0 Application Information 4.1 Schottky Diode 4.2 Conventional Shunt Regulator 4.3 Adjustable Regulator 5.0 Typical Application Circuits 6.0 Packaging Information 6.1 Package Marking Information APPENDIX A: Revision History Product Identification System Worldwide Sales and Service
