Клеммники KEEN SIDE
Datasheet LTC4301 (Analog Devices) - 4
ОписаниеSupply Independent Hot Swappable 2-Wire Bus Buffer
Страниц / Страница12 / 4 — PI FU CTIO S. CS (Pin 1):. SDAIN (Pin 6):. SCLOUT (Pin 2):. SDAOUT (Pin …
Формат / Размер файлаPDF / 229 Кб
PI FU CTIO S. CS (Pin 1):. SDAIN (Pin 6):. SCLOUT (Pin 2):. SDAOUT (Pin 7):. SCLIN (Pin 3):. CC (Pin 8):. GND (Pin 4):
PI FU CTIO S CS (Pin 1): SDAIN (Pin 6): SCLOUT (Pin 2): SDAOUT (Pin 7): SCLIN (Pin 3): CC (Pin 8): GND (Pin 4):
29 предложений от 18 поставщиков
Интегральные микросхемы Интерфейс - Буферы сигналов, Повторители, Распределители
LTC4301CDD#TRPBF
222 ₽
Эиком
LTC4301CDD#PBF
от 662 ₽
LTC4301CDD#TRPBF
SUV System
LTC4301CDD#PBF
LTC4301
U U U PI FU CTIO S CS (Pin 1):
The connection sense pin is a 1.4V threshold when the start-up sequence described in the Operation digital input pin. For normal operation CS is grounded. section has not been completed. READY goes high when Driving CS above the 1.4V threshold isolates SDAIN from CS is low and a start-up is complete. SDAOUT and SCLIN from SCLOUT and asserts READY
SDAIN (Pin 6):
Serial Data Input. Connect this pin to the low. SDA bus on the backplane.
SCLOUT (Pin 2):
Serial Clock Output. Connect this pin to
SDAOUT (Pin 7):
Serial Data Output. Connect this pin to the SCL bus on the card. the SDA bus on the card.
SCLIN (Pin 3):
Serial Clock Input. Connect this pin to SCL
V
on the bus backplane.
CC (Pin 8):
Main Input Supply. Place a bypass capacitor of at least 0.01µF close to VCC for best results.
GND (Pin 4):
Ground. Connect this pin to a ground plane
Exposed Pad (Pin 9):
Exposed pad may be left open or for best results. connected to device ground.
READY (Pin 5):
The READY pin is an open drain N-channel MOSFET output which pulls down when CS is high or
W BLOCK DIAGRA LTC4301 Supply Independent 2-Wire Bus Buffer
PRECHARGE VCC 8 CONNECT R1 R2 PRECHARGE PRECHARGE R3 R4 200k 200k CONNECT CONNECT 200k 200k SDAIN SDAOUT 6 7 CONNECT SCLIN SCLOUT 3 2 PRECHARGE LOGIC CONNECT 1.8V 1.8V READY CS CONNECT 5 1 95µs UVLO DELAY 1.4V CONNECT GND 4 4301 BD 4301fb 4
