Datasheet LTC4318 (Analog Devices) - 10
ОписаниеDual I2C/SMBus Address Translator
Страниц / Страница16 / 10 — operaTion Table 2. Setting the Resistive Divider at XORL. LOWER. 4-BIT …
Формат / Размер файлаPDF / 225 Кб
operaTion Table 2. Setting the Resistive Divider at XORL. LOWER. 4-BIT OF. TRANSLATION. BYTE. RECOMMENDED RECOMMENDED. a3 a2 a1 a0
operaTion Table 2 Setting the Resistive Divider at XORL LOWER 4-BIT OF TRANSLATION BYTE RECOMMENDED RECOMMENDED a3 a2 a1 a0
17 предложений от 11 поставщиков
Dual I2C/SMBus Address Translator / IC ACCELERATOR I2C HOTSWAP 20DFN
LTC4318IUF#PBF
631 ₽
Элитан
LTC4318IUF
697 ₽
Эиком
LTC4318IUF#PBF
699 ₽
727GS
LTC4318IUF#PBF
от 703 ₽
LTC4318
which gives 0110 0010b or 0x62. If the configuration
LOWER
voltages at XORL and XORH pins are the same, they can
4-BIT OF
be tied together and connected to a single resistive divider.
TRANSLATION BYTE
Alternatively, three resistors can be used to configure
RECOMMENDED RECOMMENDED a3 a2 a1 a0 V
the XORL and XORH pins (Figure 6). Use the following
XORL/VCC RLT [kΩ] RLB [kΩ]
0 0 0 0 ≤ 0.03125 Open Short procedure to calculate the value of the three resistors: 0 0 0 1 0.09375 ±0.015 976 102 0 0 1 0 0.15625 ±0.015 976 182 VCC 0 0 1 1 0.21875 ±0.015 1000 280 RA1 VCC 0 1 0 0 0.28125 ±0.015 1000 392 XORL 0 1 0 1 0.34375 ±0.015 1000 523 LTC4318 RA2 0 1 1 0 0.40625 ±0.015 1000 681 XORH 0 1 1 1 0.46875 ±0.015 1000 887 RA3 1 0 0 0 0.53125 ±0.015 887 1000 4318 F06 1 0 0 1 0.59375 ±0.015 681 1000 1 0 1 0 0.65625 ±0.015 523 1000
Figure 6. Address Translation Byte
1 0 1 1 0.71875 ±0.015 392 1000
Configuration Using Three Resistors
1 1 0 0 0.78125 ±0.015 280 1000 1 1 0 1 0.84375 ±0.015 182 976 First choose a total resistance value RTOTAL 1 1 1 0 0.90625 ±0.015 102 976 1 1 1 1 ≥ 0.96875 Short Open RA3 = RTOTAL • (VXORH/VCC) RA2 = (RTOTAL • VXORL/VCC) – RA3
Table 3. Setting the Resistive Divider at XORH
RA1 = RTOTAL – RA3 – RA2
UPPER 3-BIT OF
Use 1% tolerance resistors for RA1, RA2 and RA3.
TRANSLATION BYTE
Once the XORL and XORH pins are read, the LTC4318
RECOMMENDED RECOMMENDED a6 a5 a4 V
turns on switches N1 and N2, connecting the input and
XORH/VCC RHT {kΩ] RHB [kΩ}
0 0 0 ≤ 0.03125 Open Short output, and the READY pin goes high to indicate that the 0 0 1 0.09375 ±0.015 976 102 LTC4318 is ready to start address translation. 0 1 0 0.15625 ±0.015 976 182 The address translation byte can be changed during 0 1 1 0.21875 ±0.015 1000 280 operation by changing the XORH and XORL voltages and 1 0 0 0.28125 ±0.015 1000 392 toggling the ENABLE pin (high-low-high). This triggers 1 0 1 0.34375 ±0.015 1000 523 the LTC4318 to re-read the XORL and XORH voltages. 1 1 0 0.40625 ±0.015 1000 681 1 1 1 0.46875 ±0.015 1000 887
Enable/UVLO
If the ENABLE pin is driven below 1.4V or if VCC is be- For example, if RLT = 976k, RLB = 102k, RHT = 1000k, and low the UVLO threshold, the LTC4318 shuts down. The RHB = 280k, the lower 4 translation bits are 0001b and internal shift register storing the address translation byte the upper 3 bits are 011b. The 8-bit hexadecimal address is cleared, address translation is disabled, switches N1, translation byte is obtained by adding a 0 as the LSB, N2 and N3 are off, the READY pin is pulled low and the quiescent current drops to 350µA. 4318fa 10 For more information www.linear.com/LTC4318
