Datasheet ICL7106, ICL7107, ICL7107S (Intersil) - 8
ПроизводительIntersil
Описание31/2 Digit, LCD/LED Display, A/D Converters
Страниц / Страница17 / 8 — TO LCD. ICL7106. DECIMAL. POINT. POINTS. SELECT. TEST. CD4030. GND. …
Версия02-11-2017
Формат / Размер файлаPDF / 935 Кб
TO LCD. ICL7106. DECIMAL. POINT. POINTS. SELECT. TEST. CD4030. GND. BACKPLANE. LCD PHASE DRIVER. TYPICAL SEGMENT OUTPUT. SEGMENT. 200. DECODE. 0.5mA
TO LCD ICL7106 DECIMAL POINT POINTS SELECT TEST CD4030 GND BACKPLANE LCD PHASE DRIVER TYPICAL SEGMENT OUTPUT SEGMENT 200 DECODE 0.5mA
31 предложений от 29 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Устройства управления дисплеем
ICL7106CPL-3
Maxim
65 ₽
ICL7106CPL
Harris
81 ₽
ICL7106CPL
98 ₽
ТаймЧипс
ICL7106CPL+
Maxim
link to page 8 link to page 9 link to page 9 ICL7106, ICL7107, ICL7107S Digital Section
V+ V+
Figures 7 and 8 show the digital section for the ICL7106 and
BP
ICL7107, respectively. In the ICL7106, an internal digital ground is generated from a 6V Zener diode and a large P-Channel source
TO LCD
follower. This supply is made stiff to absorb the relatively large
ICL7106 DECIMAL DECIMAL
capacitive currents when the back plane (BP) voltage is switched.
POINT POINTS SELECT
The BP frequency is the clock frequency divided by 800. For three readings/sec., this is a 60Hz square wave with a nominal
TEST
amplitude of 5V. The segments are driven at the same frequency
CD4030
and amplitude and are in phase with BP when OFF, but out of
GND
phase when ON. In all cases negligible DC voltage exists across the segments. FIGURE 6. EXCLUSIVE ‘OR’ GATE FOR DECIMAL POINT DRIVE Figure 8 is the Digital Section of the ICL7107. It is identical to the ICL7106 except that the regulated supply and back plane drive have been eliminated and the segment drive has been increased from 2mA to 8mA, typical for instrument size common anode LED displays. Since the 1000 output (pin 19) must sink current from two LED segments, it has twice the drive capability or 16mA. In both devices, the polarity indication is “on” for negative analog inputs. If IN LO and IN HI are reversed, this indication can be reversed also, if desired.
a a a a f b f b f b g c g g e c e c e c b d d d BACKPLANE 21 LCD PHASE DRIVER 7 7 7 TYPICAL SEGMENT OUTPUT SEGMENT SEGMENT SEGMENT
200 V+ DECODE DECODE DECODE 0.5mA SEGMENT LATCH OUTPUT 2mA 1000’s 100’s 10’s 1’s COUNTER COUNTER COUNTER COUNTER INTERNAL DIGITAL GROUND TO SWITCH DRIVERS FROM COMPARATOR OUTPUT 1 V+ CLOCK
6.2V 4 LOGIC CONTROL 500Ω TEST † THREE INVERTERS INTERNAL ONE INVERTER SHOWN FOR CLARITY V 37 DIGITAL TH = 1V GROUND 26 V- 40 39 38 OSC 1 OSC 2 OSC 3
FIGURE 7. ICL7106 DIGITAL SECTION FN3082 Rev 9.00 Page 8 of 17 October 24, 2014
