Линейка продуктов KEEN SIDE
Datasheet ADXL363 (Analog Devices) - 7
ОписаниеMicropower 3-Sensor Combination Including Acceleration and Temperature
Страниц / Страница49 / 7 — ADXL363. Data Sheet. 12-BIT ADC SPECIFICATIONS. Table 4. Parameter. Test …
ВерсияA
ADXL363. Data Sheet. 12-BIT ADC SPECIFICATIONS. Table 4. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADXL363 Data Sheet 12-BIT ADC SPECIFICATIONS Table 4 Parameter Test Conditions/Comments Min Typ Max Unit
33 предложений от 11 поставщиков
Сенсоры, Датчики Датчики движения — акселерометры (ускорения)
727GS
ADXL363BCCZ-RL7
от 503 ₽
Зенер
Россия и страны ТС
ADXL363BCCZ-RL7
от 530 ₽
ADXL363BCCZ-RL7
от 1 391 ₽
ADXL363BCCZ-RL
ADXL363 Data Sheet 12-BIT ADC SPECIFICATIONS Table 4. Parameter Test Conditions/Comments Min Typ Max Unit
ANALOG-TO-DIGITAL CONVERTER Input Voltage Range 0.1 × VS 0.9 × VS Integral Nonlinearity (INL) VS = 1.6 V ±1.0 LSB VS = 2.0 V ±0.8 LSB VS = 3.5 V ±1.1 LSB Differential Nonlinearity (DNL) VS = 1.6 V ±1.8 LSB VS = 2.0 V ±1.6 LSB VS = 3.5 V ±2.1 LSB Offset Error VS = 1.6 V 1.6 LSB VS = 2.0 V 3.4 LSB VS = 3.5 V 9.1 LSB Gain Error VS = 1.6 V −4.3 LSB VS = 2.0 V −5.3 LSB VS = 3.5 V −11.8 LSB Throughput (ODR) User selectable in eight steps ODR Rev. 0 | Page 6 of 48 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications ADXL363 Specifications Accelerometer Specifications Temperature Sensor Specifications 12-Bit ADC Specifications Absolute Maximum Ratings Thermal Resistance Recommended Soldering Profile ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Accelerometer Mechanical Device Operation Operating Modes Measurement Mode Wake-Up Mode Standby Selectable Measurement Ranges Selectable Output Data Rates Antialiasing Power/Noise Tradeoff Free Fall Detection ADC Analog Inputs Digital Output Temperature Sensor Power Savings Features Ultralow Power Consumption in All Modes, Operating All Sensors Motion Detection Activity Detection Referenced and Absolute Configurations Fewer False Positives Inactivity Detection Linking Activity and Inactivity Detection Default Mode Linked Mode Loop Mode Autosleep Using the Awake Bit FIFO System Level Power Savings Data Recording/Event Context Communications SPI Instructions Bus Keepers MSB Registers Additional Features External Clock Synchronized Data Sampling Self Test User Register Protection Serial Communications SPI Commands Read and Write Register Commands Read FIFO Command Multibyte Transfers Register Read/Write Auto-Increment Invalid Addresses and Address Folding Latency Restrictions Invalid Commands Register Map Register Details Device ID Registers Silicon Revision ID Register X-Axis Data (8 MSB) Register Y-Axis Data (8 MSB) Register Z-Axis Data (8 MSB) Register Status Register FIFO Entries Registers X-Axis Data Registers Y-Axis Data Registers Z-Axis Data Registers Temperature Data Registers ADC Data Registers Soft Reset Register Activity Threshold Registers Activity Time Register Inactivity Threshold Registers Inactivity Time Registers Activity/Inactivity Control Register FIFO Control Register FIFO Samples Register INT1/INT2 Function Map Registers Filter Control Register Power Control Register Self Test Register Applications Information Application Examples Device Configuration Autonomous Motion Switch Startup Routine Using External Timing Using an External Clock Using Synchronized Data Sampling How to Set Up Synchronized Data Sampling Power Power Supply Decoupling Power Supply Requirements FIFO Modes FIFO Disabled Oldest Saved Mode Stream Mode Triggered Mode FIFO Configuration FIFO Interrupts Retrieving Data from FIFO Interrupts Interrupt Pins Alternate Functions of Interrupt Pins Activity and Inactivity Interrupts Data Ready Interrupt Using FIFO Interrupts FIFO Watermark FIFO Ready Overrun Using Self Test Operation at Voltages Other Than 2.0 V Mechanical Considerations for Mounting Axes of Acceleration Sensitivity Layout and Design Recommendations Outline Dimensions Ordering Guide
