Datasheet ADIS16240 (Analog Devices) - 8
ОписаниеLow Power Programmable Impact Sensor and Recorder
Страниц / Страница21 / 8 — Data Sheet. ADIS16240. TYPICAL PERFORMANCE CHARACTERISTICS. 3.3. 2.8. …
ВерсияC
Формат / Размер файлаPDF / 454 Кб
Data Sheet. ADIS16240. TYPICAL PERFORMANCE CHARACTERISTICS. 3.3. 2.8. mA). 30mA PEAK. ( NT 2.3. CURRE 1.8. Y L. CURRENT. P UP. 1.3. 0.8. 0.3. 500. 1000
Data Sheet ADIS16240 TYPICAL PERFORMANCE CHARACTERISTICS 3.3 2.8 mA) 30mA PEAK ( NT 2.3 CURRE 1.8 Y L CURRENT P UP 1.3 0.8 0.3 500 1000
11 предложений от 10 поставщиков
Акселерометры - Печатного монтажа LowPwrPgrmbl Impact Sens & Shock Recordr
ADIS16240ABCZ
444 ₽
727GS
ADIS16240ABCZ
от 815 ₽
ADIS16240ABCZ
ADIS16240ABCZ
Data Sheet ADIS16240 TYPICAL PERFORMANCE CHARACTERISTICS 3.3 2.8 mA) 30mA PEAK ( NT 2.3 CURRE 1.8 Y L CURRENT P UP 1 1.3 S 0.8
106 108
0.3
08133- 08133-
0 500 1000 1500 2000 2500 3000 3500 4000 4500 CH1 20.0V M40.0µs A CH1 17.2mV SAMPLE RATE (SPS) T 40.5304µs
Figure 6. Supply Current vs. Sample Rate Figure 9. Instantaneous Supply Current
1.6 1.4 30mA PEAK 1.2 mA) ( 1.0 NT 0.8 CURRE Y CURRENT L 0.6 P 1 UP S 0.4 0.2
109 107 08133-
0
08133-
CH1 50.0V M40.0µs A CH1 73.0mV 2.4 2.6 2.8 3.0 3.2 3.4 3.6 T 40.5304µs SUPPLY VOLTAGE (V)
Figure 7. Supply Current vs. Supply Voltage Figure 10. Instantaneous Supply Current
1.5 3.6V 1.4 3.0V mA) ( 1.3 NT 1.2 CURRE Y L P 1.1 UP S 2.4V 1.0
110
0.9
08133-
–40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 TEMPERATURE (°C)
Figure 8. Supply Current vs. Temperature Rev. C | Page 7 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Sensing Element Data Sampling and Processing User Interface SPI Interface User Registers Capture Basic Operation SPI Write Commands Memory Map Output Data Registers Processing Sensor Data Event Recorder Internal Trigger Setup External Trigger Setup Buffer Memory Configuration Event Organization Reading Event Data Transient Behavior During Capture Operational Control Internal Sample Rate Global Commands Input/Output Lines Offset Adjustment Diagnostics Clock Checksum Flash Memory Endurance Management Applications Information Assembly Interface Printed Circuit Board (PCB) Outline Dimensions Ordering Guide
