Datasheet ADXL335 (Analog Devices) - 8
ОписаниеSmall, Low Power, 3-Axis ±3 g Accelerometer
Страниц / Страница17 / 8 — ADXL335. 1.55. N = 8. 1.54. 1.53. 1.52. IO T. 1.51. ( T. U 1.50 TP. PO F. …
ВерсияB
Формат / Размер файлаPDF / 384 Кб
ADXL335. 1.55. N = 8. 1.54. 1.53. 1.52. IO T. 1.51. ( T. U 1.50 TP. PO F. OU 1.49. O %. 1.48. 1.47. 1.46. 1.45. –3.0 –2.5 –2.0 –1.5 –1.0 –0.5
ADXL335 1.55 N = 8 1.54 1.53 1.52 IO T 1.51 ( T U 1.50 TP PO F OU 1.49 O % 1.48 1.47 1.46 1.45 –3.0 –2.5 –2.0 –1.5 –1.0 –0.5
64 предложений от 25 поставщиков
ACCELEROMETER 3G ANALOG 16LFCSP. Accelerometer X, Y, Z Axis ±3g 1.6kHz (X,Y), 550Hz (Z) 16-LFCSP-LQ (4x4). Motion Sensors - Accelerometers
Microfind
ADXL335BCPZ-RL7
от 323 ₽
Эиком
ADXL335BCPZ-RL
от 998 ₽
LifeElectronics
ADXL335BCPZ-RL7
ADXL335BCPZ-RL
ADXL335 30 1.55 N = 8 1.54 25 1.53 N 1.52 20 IO T ) A 1.51 V L ( T PU 15 U 1.50 TP PO F OU 1.49 O % 10 1.48 1.47 5 1.46 0
1
1.45 –3.0 –2.5 –2.0 –1.5 –1.0 –0.5 0 0.5 1.0 1.5 2.0 2.5 3.0
4 01
–40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 100
01 8- 8-
TEMPERATURE COEFFICIENT (mg /°C)
80 80 07
TEMPERATURE (°C)
07 Figure 9. X-Axis Zero g Bias Temperature Coefficient, VS = 3 V Figure 12. X-Axis Zero g Bias vs. Temperature— Eight Parts Soldered to PCB
40 1.55 N = 8 1.54 1.53 30 N 1.52 IO T ) A 1.51 V L ( T PU 20 U 1.50 TP PO F OU 1.49 O % 1.48 10 1.47 1.46 0
2
01
15 0 8- 8-
80
TEMPERATURE (°C)
80 07 07 Figure 10. Y-Axis Zero g Bias Temperature Coefficient, VS = 3 V Figure 13. Y-Axis Zero g Bias vs. Temperature— Eight Parts Soldered to PCB
20 1.50 N = 8 1.48 1.46 15 N 1.44 IO T ) A 1.42 V L ( T PU 10 U 1.40 TP PO F OU 1.38 O % 1.36 5 1.34 1.32 0 1.30 –7 –6 –5 –4 –3 –2 –1 0 1 2 3 4 5 6 7
13 6 -0
01 08 8-
78
TEMPERATURE (°C)
80 0 07 Figure 11. Z-Axis Zero g Bias Temperature Coefficient, V Figure 14. Z-Axis Zero g Bias vs. Temperature— S = 3 V Eight Parts Soldered to PCB Rev. B | Page 7 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL SENSOR PERFORMANCE APPLICATIONS INFORMATION POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH USING CX, CY, AND CZ SELF-TEST DESIGN TRADE-OFFS FOR SELECTING FILTER CHARACTERISTICS: THE NOISE/BW TRADE-OFF USE WITH OPERATING VOLTAGES OTHER THAN 3 V AXES OF ACCELERATION SENSITIVITY LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
