Datasheet ADXL213 (Analog Devices) - 4
ОписаниеLow Cost ±1.2g Dual Axis Accelerometer
Страниц / Страница13 / 4 — ADXL213. SPECIFICATIONS. Table 1. Parameter Conditions. Min. Typ. Max. …
ВерсияA
Формат / Размер файлаPDF / 218 Кб
ADXL213. SPECIFICATIONS. Table 1. Parameter Conditions. Min. Typ. Max. Unit
ADXL213 SPECIFICATIONS Table 1 Parameter Conditions Min Typ Max Unit
40 предложений от 22 поставщиков
ACCELEROMETER 1.2G PWM 8LCC. Accelerometer X, Y Axis ±1.2g 1Hz ~ 2.5kHz 8-LCC (5x5). Motion Sensors - Accelerometers
ЧипСити
ADXL213AE-REEL
52 ₽
ADXL213AE-REEL
992 ₽
Контест
ADXL213AE
2 183 ₽
LifeElectronics
ADXL213AE
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
TA = –40°C to +85°C, VS = 5 V, CX = CY = 0.1 μF, Acceleration = 0 g, unless otherwise noted. All minimum and maximum specifications are guaranteed. Typical specifications are not guaranteed.
Table 1. Parameter Conditions Min Typ Max Unit
SENSOR INPUT Each axis Measurement Range1 ±1.2 g Nonlinearity % of full scale ±0.5 % Package Alignment Error ±1 Degrees Alignment Error X sensor to Y sensor ±0.1 Degrees Cross Axis Sensitivity ±2 % SENSITIVITY (Ratiometric)2 Each axis Sensitivity at XOUT, YOUT VS = 5 V 27 30 33 %/g Sensitivity Change due to Temperature3 VS = 5 V ±0.3 % ZERO g BIAS LEVEL (Ratiometric) Each axis 0 g Voltage at XOUT, YOUT VS = 5 V ±50 % Initial 0 g Output Deviation from Ideal VS = 5 V, 25°C ±2 % 0 g Offset vs. Temperature ±0.25 mg/°C NOISE PERFORMANCE Noise Density @25°C 160 μg/√Hz rms FREQUENCY RESPONSE4 CX, CY Range5 0.002 4.7 μF RFILT Tolerance 22 32 42 kΩ Sensor Resonant Frequency 5.5 kHz SELF TEST6 Logic Input Low 1 V Logic Input High 4 V ST Input Resistance to Ground 30 50 kΩ Output Change at XOUT, YOUT Self test 0 to 1 23 % PWM Output FSET RSET = 125 kΩ 1 kHz T2 Drift versus Temperature ±0.3 % POWER SUPPLY Operating Voltage Range 3 6 V Quiescent Supply Current 0.7 1.1 mA Turn-On Time7 20 ms 1 Guaranteed by measurement of initial offset and sensitivity. 2 Sensitivity varies with VS. At VS = 3 V, sensitivity is typically 28%/g. 3 Defined as the output change from ambient-to-maximum temperature or ambient-to-minimum temperature. 4 Actual frequency response controlled by user-supplied external capacitor (CX, CY). 5 Bandwidth = 1/(2 × π × 32 kΩ × C). For CX, CY = 0.002 μF, Bandwidth = 2500 Hz. For CX, CY = 4.7 μF, Bandwidth = 1 Hz. Minimum/maximum values are not tested. 6 Self-test response changes with VS. At VS = 3 V, self-test output is typically 8%. 7 Larger values of CX, CY increase turn-on time. Turn-on time is approximately 160 × CX or CY + 4 ms, where CX, CY are in μF. Rev. A | Page 3 of 12 Document Outline REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION PERFORMANCE APPLICATIONS POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH USING CX AND CY SELF TEST DESIGN TRADE-OFFS FOR SELECTING FILTER CHARACTERISTICS: THE NOISE/BW TRADE-OFF USING THE ADXL213 WITH OPERATING VOLTAGES OTHER THAN 5 V USING THE ADXL213 AS A DUAL-AXIS TILT SENSOR Dual-Axis Tilt Sensor: Converting Acceleration to Tilt PIN CONFIGURATIONS AND FUNCTIONAL DESCRIPTIONS OUTLINE DIMENSIONS ESD CAUTION ORDERING GUIDE AUTOMOTIVE PRODUCTS
