Datasheet AD652 (Analog Devices) - 6
ОписаниеMonolithic Synchronous Voltage-to-Frequency Converter
Страниц / Страница12 / 6 — STANDARD. 5962-93222. MICROCIRCUIT DRAWING
Формат / Размер файлаPDF / 109 Кб
STANDARD 5962-93222 MICROCIRCUIT DRAWING
25 предложений от 21 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Преобразователи "частота-напряжение" и "напряжение-частота"
AD652AQ
846 ₽
AD652AQ
901 ₽
AD652AQ
1 664 ₽
SUV System
AD652AQ
TABLE I. Electrical performance characteristics – Continued. Conditions 1/ Test Symbol -55C  TA +125C Group A Device Limits Unit ±V subgroups type S = 15 V unless otherwise specified Min Max Op amp output voltage 3/ V 1,2 11 V S = 15 V, op amp 01 V range R railed high 3 10.3 V 1,3 -1 S = 15 V, op amp railed low 2 -0.6 Max clock frequency 3/ fCLOCK VIN = 0.01 V, 9.4 V 4,5,6 01 4 MHz Referred to DIGITAL GND Clock threshold voltage VCT 1,2,3 01 0.8 2.0 V pin Clock input current 3/ IC CLOCK IN pin = 0 V 1,2,3 01 20 A Low level output 3/ V voltage 1 OL1 IOUT = 15 mA 1,2,3 01 0.8 V IOUT = 10 mA 0.4 Low level output voltage 2 VOL2 IOUT = 8 mA 1,2,3 0.4 Leakage current 3/ IL VOUT = 36 V 1,2,3 01 10 A Reference voltage VREF IREF = 0 mA 1 01 4.95 5.05 V Reference voltage TCV temperature coefficient REF IREF = 0 mA 2,3 01 100 ppm/C Quiescent current 3/ ISS VS = 15 V, VIN = 0.1 V 1,2,3 01 15 mA Delay time positive clock 3/ fCLOCK = 200 kHz, 9 01 150 250 t ns edge to output pulse D COS pin to +VS pin 10,11 150 350 Output pulse width 3/ tPW COS = 300 pF 9,10,11 01 1 2 s 1/ 0.1 F decoupling capacitors from +VS to ground and –VS to ground. 2/ Nonlinearity is defined as the deviation from a straight line from zero to full scale, expressed as a fraction of full scale. 3/ Additional test parameters applicable to final electrical and group A subgroups 2, 3, 5, 6, 10, and 11 for device class V only. 4/ Offset is guaranteed adjustable to zero using a 10 k potentiometer on both TRIM pins with the wiper connected to +VS through a 250 k resistor.
STANDARD
SIZE
5962-93222 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 C 6 DSCC FORM 2234 APR 97
