Datasheet ADIS16475 (Analog Devices) - 3
ОписаниеPrecision, Miniature MEMs IMU (2000dps, 8g)
Страниц / Страница34 / 3 — ADIS16475. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 11/2017—Rev. 0 …
ВерсияC
ADIS16475. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 11/2017—Rev. 0 to Rev. A. 10/2017—Revision 0: Initial Version
ADIS16475 Data Sheet TABLE OF CONTENTS REVISION HISTORY 11/2017—Rev 0 to Rev A 10/2017—Revision 0: Initial Version
17 предложений от 12 поставщиков
6 DOF PREC IMU, 8G (500 DPS DNR). Accelerometer, Gyroscope, 6 Axis Sensor SPI Output. Motion Sensors - IMUs (Inertial Measurement...
ADIS16475-2BMLZ
39 104 ₽
ADIS16475-2BMLZ
42 520 ₽
ADIS16475-2BMLZ
54 639 ₽
Элитан
ADIS16475-2BMLZ
168 158 ₽
link to page 1 link to page 1 link to page 1 link to page 1 link to page 4 link to page 6 link to page 8 link to page 8 link to page 8 link to page 9 link to page 11 link to page 12 link to page 12 link to page 12 link to page 13 link to page 14 link to page 14 link to page 15 link to page 16 link to page 17 link to page 19 link to page 19 link to page 22 link to page 23 link to page 25 link to page 31 link to page 31 link to page 32 link to page 32 link to page 34 link to page 34 link to page 34
Features .. 1 Reading Sensor Data .. 14 Applications ... 1 Device Configuration .. 15 General Description ... 1 User Register Memory Map .. 16 Functional Block Diagram .. 1 User Register Defintions .. 18 Specifications ... 3 Gyroscope Data .. 18 Timing Specifications .. 5 Delta Angles .. 21 Absolute Maximum Ratings ... 7 Delta Velocity .. 22 Thermal Resistance .. 7 Calibration... 24 ESD Caution .. 7 Applications Information .. 30 Pin Configuration and Function Descriptions ... 8 Assembly and Handling Tips .. 30 Typical Performance Characteristics ... 10 Power Supply Considerations ... 31 Theory of Operation .. 11 Evaluation Tools ... 31 Introduction .. 11 Packaging and Ordering Information ... 33 Inertial Sensor Signal Chain ... 11 Outline Dimensions ... 33 Register Structure ... 12 Ordering Guide .. 33 Serial Peripheral Interface (SPI) ... 13 Data Ready (DR) .. 13
Changes to Table 1 .. 3 Deleted Endnote 1, Table 1; Renumbered Sequential y .. 4 Added Endnote 2, Table 1; Renumbered Sequential y .. 4
Rev. A | Page 2 of 33 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INTRODUCTION INERTIAL SENSOR SIGNAL CHAIN Gyroscope Data Sampling Accelerometer Data Sampling External Clock Options Inertial Sensor Calibration Bartlett Window FIR Filter Averaging/Decimating Filter REGISTER STRUCTURE SERIAL PERIPHERAL INTERFACE (SPI) DATA READY (DR) READING SENSOR DATA Burst Read Function DEVICE CONFIGURATION Memory Structure USER REGISTER MEMORY MAP USER REGISTER DEFINTIONS Status/Error Flag Indicators (DIAG_STAT) GYROSCOPE DATA Gyroscope Measurement Range/Scale Factor Gyroscope Data Formatting X-Axis Gyroscope (X_GYRO_LOW and X_GYRO_OUT) Y-Axis Gyroscope (Y_GYRO_LOW and Y_GYRO_OUT) Z-Axis Gyroscope (Z_GYRO_LOW and Z_GYRO_OUT) Acceleration Data Accelerometer Resolution X-Axis Accelerometer (X_ACCL_LOW and X_ACCL_OUT) Y-Axis Accelerometer (Y_ACCL_LOW and Y_ACCL_OUT) Z-Axis Accelerometer (Z_ACCL_LOW and Z_ACCL_OUT) Internal Temperature (TEMP_OUT) Time Stamp (TIME_STAMP) Data Update Counter (DATA_CNTR) DELTA ANGLES Delta Angle Measurement Range X-Axis Delta Angle (X_DELTANG_LOW and X_DELTANG_OUT) Y-Axis Delta Angle (Y_DELTANG_LOW and Y_DELTANG_OUT) Z-Axis Delta Angle (Z_DELTANG_LOW and Z_DELTANG_OUT) Delta Angle Resolution DELTA VELOCITY X-Axis Delta Velocity (X_DELTVEL_LOW and X_DELTVEL_OUT) Y-Axis Delta Velocity (Y_DELTVEL_LOW and Y_DELTVEL_OUT) Z-Axis Delta Velocity (Z_DELTVEL_LOW and Z_DELTVEL_OUT) Delta Velocity Resolution CALIBRATION Calibration, Gyroscope Bias (XG_BIAS_LOW and XG_BIAS_HIGH) Calibration, Gyroscope Bias (YG_BIAS_LOW and YG_BIAS_HIGH) Calibration, Gyroscope Bias (ZG_BIAS_LOW and ZG_BIAS_HIGH) Calibration, Accelerometer Bias (XA_BIAS_LOW and XA_BIAS_HIGH) Calibration, Accelerometer Bias (YA_BIAS_LOW and YA_BIAS_HIGH) Calibration, Accelerometer Bias (ZA_BIAS_LOW and ZA_BIAS_HIGH) Filter Control Register (FILT_CTRL) Range Identifier (RANG_MDL) Miscellaneous Control Register (MSC_CTRL) Point of Percussion Linear Acceleration Effect on Gyroscope Bias Internal Clock Mode Output Sync Mode Direct Sync Mode Pulse Sync Mode Scaled Sync Mode Decimation Filter (DEC_RATE) Data Update Rate in External Sync Modes Continuous Bias Estimation (NULL_CNFG) Global Commands (GLOB_CMD) Software Reset Flash Memory Test Flash Memory Update Sensor Self Test Factory Calibration Restore Bias Correction Update Firmware Revision (FIRM_REV) Firmware Revision Day and Month (FIRM_DM) Firmware Revision Year (FIRM_Y) Product Identification (PROD_ID) Serial Number (SERIAL_NUM) Scratch Registers (USER_SCR_1 to USER_SCR_3) Flash Memory Endurance Counter (FLSHCNT_LOW and FLSHCNT_HIGH) APPLICATIONS INFORMATION ASSEMBLY AND HANDLING TIPS Package Attributes Assembly Tips PCB Layout Suggestions Underfill Process Validation and Control POWER SUPPLY CONSIDERATIONS EVALUATION TOOLS Breakout Boards PC-Based Evaluation, EVAL-ADIS2 PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
