Datasheet ADXRS290 (Analog Devices) - 2
ОписаниеUltralow noise, dual-axis MEMS Gyroscope for Stabilization Applications
Страниц / Страница20 / 2 — ADXRS290* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
ВерсияA
Формат / Размер файлаPDF / 578 Кб
ADXRS290* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADXRS290* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
26 предложений от 11 поставщиков
Датчики Гироскопов, Gyroscope Dual 2000G ±100°/s 5V 18Pin LGA T/R
ADXRS290BCEZ-RL7
от 637 ₽
ЧипСити
ADXRS290BCEZ-RL7
1 355 ₽
ADXRS290BCEZ-RL7
1 397 ₽
ADXRS290BCEZ-RL7
View a parametric search of comparable parts. • ADXRS290 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADXRS290Z Evaluation Board • Symbols and Footprints • ADXRS290Z-M Evaluation Board • Real Time Eval System for Digital Output Sensor
DISCUSSIONS
View all ADXRS290 EngineerZone Discussions.
DOCUMENTATION Data Sheet SAMPLE AND BUY
• ADXRS290: Ultralow Noise, Dual-Axis Gyroscope Data Visit the product page to see pricing options. Sheet
User Guides TECHNICAL SUPPORT
• UG-780: Evaluation Board for ADXRS290, Ultralow Noise, Submit a technical question or find your regional support Dual-Axis MEMS Gyroscope number. • UG-783: Using the EVAL-ADXRS290Z-M Inertial Sensor Evaluation System for the ADXRS290
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
REFERENCE MATERIALS Technical Articles
• Designing For Low Noise Feedback Control With Mems Gyroscopes
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXES PACKAGE INFORMATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION APPLICATION CIRCUIT POWER SUPPLY DECOUPLING POWER SEQUENCING SETTING BANDWIDTH Offset Preservation in the High-Pass Filter ANALOG EVALUATION MODE MECHANICAL CONSIDERATIONS FOR MOUNTING SERIAL COMMUNICATIONS REGISTER MAP REGISTER DESCRIPTIONS ANALOG DEVICES IDENTIFIER MEMS IDENTIFIER DEVICE IDENTIFIER SILICON REVISION NUMBER SERIAL NUMBER (SNx) RATE OUTPUT DATA Register 0x08 to Register 0x0B: DATAX0, DATAX1, DATAY0, and DATAY1 (Read Only) TEMPERATURE DATA Register 0x0C to Register 0x0D: TEMP0 and TEMP1 (Read Only) POWER CONTROL TSM Bit Measurement Bit BAND-PASS FILTER LPF Bits HPF Bits DATA READY Sync Bits RECOMMENDED SOLDERING PROFILE PCB FOOTPRINT PATTERN OUTLINE DIMENSIONS ORDERING GUIDE
