Линейка продуктов KEEN SIDE
Datasheet ADXRS810 (Analog Devices) - 2
ОписаниеHigh Performance, SPI Digital Output, Angular Rate Sensor
Страниц / Страница29 / 2 — ADXRS810* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
Формат / Размер файлаPDF / 677 Кб
ADXRS810* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DISCUSSIONS. DOCUMENTATION
ADXRS810* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DISCUSSIONS DOCUMENTATION
11 предложений от 9 поставщиков
Датчики Гироскопов, MEMS Gyroscopes Single Axis ±300°/s Automotive 16Pin SOIC Tape and Reel
ADXRS810WBRGZ-RL
от 913 ₽
ADXRS810WBRGZ-RL
1 184 ₽
ЗУМ-СМД
ADXRS810BRGZ
ADXRS810WBRGZ-RL
View a parametric search of comparable parts. View all ADXRS810 EngineerZone Discussions.
DOCUMENTATION SAMPLE AND BUY Data Sheet
Visit the product page to see pricing options. • ADXRS810: High Performance, SPI Digital Output, Angular Rate Sensor Data Sheet
TECHNICAL SUPPORT
Submit a technical question or find your regional support
DESIGN RESOURCES
number. • ADXRS810 Material Declaration • PCN-PDN Information
DOCUMENT FEEDBACK
• Quality And Reliability Submit feedback for this data sheet. • Symbols and Footprints
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Thermal Resistance Rate Sensitive Axis ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Continuous Self-Test Applications Information Calibrated Performance Mechanical Considerations for Mounting Application Circuit ADXRS810 Signal Chain Timing SPI Communications Characteristics SPI Communication Protocol—Applications Device Data Latching Command/Response SPI Communication Protocol—Bit Definitions Command/Response Bit Descriptions ADXRS810 Fault Register Bit Definitions CHK Bit Assertion: Recommended Start-Up Routine SPI Rate Data Format ADXRS810 Memory Map Memory Register Definitions 0x00 RATE1, 0x01 RATE0 0x02 TEM1, 0x03 TEM0 0x04 LOCST1, 0x05 LOCST0 0x06 HICST1, 0x07 HICST0 0x08 QUAD1, 0x09 QUAD0 0x0A FAULT1, 0x0B FAULT0 0x0C PID1, 0x0D PID0 0x0E SN3, 0x0F SN2, 0x10 SN1, 0x11 SN0 Suggested PCB Layout Solder Profile Package Marking Codes Outline Dimensions Ordering Guide Automotive Products
