Datasheet ADXRS649 (Analog Devices) - 9
ОписаниеFast Starting, ±20,000°/sec Vibration Rejecting Rate Gyro
Страниц / Страница13 / 9 — ADXRS649. Data Sheet. 0.5. 0.4. 0.3. 0.2. eak). %) ( Y. 0.1. °/sec P. …
ВерсияB
Формат / Размер файлаPDF / 347 Кб
ADXRS649. Data Sheet. 0.5. 0.4. 0.3. 0.2. eak). %) ( Y. 0.1. °/sec P. ARI. INE. –0.1. RAT. –0.2. 0.01. –0.3. –0.4. 0.001. –0.5. 100. 1000. 10000. 5000. 15000. 20000
ADXRS649 Data Sheet 0.5 0.4 0.3 0.2 eak) %) ( Y 0.1 °/sec P ARI INE –0.1 RAT –0.2 0.01 –0.3 –0.4 0.001 –0.5 100 1000 10000 5000 15000 20000
IC GYROSCOPE YAW RATE 32CBGA. Gyroscope Z (Yaw) ±20000 2kHz Analog Voltage 32-CBGA (7x7). Motion Sensors - Gyroscopes
Microfind
ADXRS649BBGZ-RL
9 222 ₽
ADXRS649BBGZ-RL
14 165 ₽
ADXRS649BBGZ-RL
ADXRS649BBGZ-RL
ADXRS649 Data Sheet 10 0.5 0.4 0.3 1 0.2 eak) %) ( Y 0.1 T °/sec P ARI ( 0.1 0 UT INE O –0.1 E NL NO RAT –0.2 0.01 –0.3 –0.4 0.001 –0.5 100 1000 10000 0 5000 10000 15000 20000
016 017
VIBRATION INPUT FREQUENCY (Hz) ANGULAR RATE (Degress per Second)
09573- 09573- Figure 16. Typical Response to 10 g RMS Sinusoidal Vibration Figure 17. Typical Nonlinearity (Four Typical Devices) (Sensor Bandwidth = 1 kHz) Rev. B | Page 8 of 12 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Rate Sensitive Axis ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Setting the Bandwidth Temperature Output and Calibration Modifying the Measurement Range Null Bias Adjustment Self-Test Function Continuous Self-Test Outline Dimensions Ordering Guide
