Datasheet AD8452 (Analog Devices) - 5
ОписаниеPrecision Integrated Analog Front End, Controller, and PWM for Battery Test and Formation Systems
Страниц / Страница35 / 5 — AD8452. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
ВерсияA
Формат / Размер файлаPDF / 754 Кб
AD8452. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD8452 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
23 предложений от 13 поставщиков
Интегральные микросхемы Микросхемы специального назначения
AD8452ASTZ-RL
742 ₽
Зенер
Россия и страны ТС
AD8452ASTZ
от 771 ₽
Microfind
AD8452ASTZ-RL
1 173 ₽
Элитан
AD8452ASTZ
1 957 ₽
CC AND CV LOOP FILTER AMPLIFIERS Offset Voltage 150 µV Offset Voltage Drift TA = TMIN to TMAX −1 +0.02 1 µV/°C Input Bias Current −5 +5 nA Input Common-Mode Voltage Range AVEE + 1.5 AVCC − 1.8 V Output Voltage Swing VVINT voltage range AVEE + 1.5 5 V Source Short-Circuit Current 1 mA Sink Short-Circuit Current 40 mA PSRR ΔVS = 10 V 113 122 dB Small Signal Gain Bandwidth Product 3 MHz Slew Rate ΔVVINT = 10 V 1 V/μs CC to CV Transition Time 1.8 µs VSET VOLTAGE BUFFER Nominal Gain 1 V/V Offset Voltage 150 µV Offset Voltage Drift TA = TMIN to TMAX −1 +0.06 +1 µV/°C Input Bias Current −5 +5 nA Input/Output Voltage Range AVEE + 1.5 AVCC − 1.8 V Short-Circuit Current 40 mA PSRR ΔVS = 10 V 113 122 dB Small Signal −3 dB Bandwidth 4 MHz Slew Rate ΔVVSETBF = 10 V 1 V/μs VOLTAGE REFERENCE Nominal Output Voltage With respect to AGND 2.5 V Output Voltage Error ±1 % Temperature Drift TA = TMIN to TMAX 16 ppm/°C Line Regulation ΔVS = 10 V 10 ppm/V Load Regulation ΔIVREF = 1 mA (source only) 300 ppm/mA Source Short-Circuit Current 15 mA Rev. 0 | Page 4 of 34 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Analog Front-End and Controller Specifications Pulse-Width Modulator Specifications Digital Interface Specifications Power Supply Temperature Range Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics In-Amp Characteristics Difference Amplifier Characteristics CC and CV Loop Filter Amplifiers and VSET Buffer (except where Noted) Reference Characteristics Pulse-Width Modulator Theory of Operation Introduction Instrumentation Amplifier (In-Amp) Reversing Polarity When Charging and Discharging In-Amp Offset Option Battery Reversal and Overvoltage Protection Difference Amplifier CC and CV Loop Filter Amplifiers Charging Lithium-Ion (Li-Ion) Cells Concepts of Constant Current (CC) and Constant Voltage (CV) Compensation Charge and Discharge Control Conditions to Charge and Discharge a Battery MODE Pin Input and Output Supply Pins Shutdown Undervoltage Lockout (UVLO) Soft Start PWM Drive Signals Peak Current Protection and Diode Emulation (Synchronous) Peak Current-Limit Detection Diode Emulation/Synchronous Mode Operation Frequency and Phase Control Internal Frequency Control External Frequency Control Operating Frequency Phase Shift Maximum Duty Cycle Fault Input Thermal Shutdown (TSD) Applications Information Analog Controller Functional Description Power Supply Connections Current Sense In-Amp Connections Current Sensors Optional Low-Pass Filter Voltage Sense Differential Amplifier Connections Battery Current and Voltage Control Inputs (ISET and VSET) Loop Filter Amplifiers Selecting Charge or Discharge Options Select RCL and RCLVT for the Peak Current Limit Setting the Operating Frequency and Programming the Synchonization Pin Select RFREQ for Standalone or Master Clock Selecting RFREQ for a Slave Device Programming the External Clock Phase Shift Programming the Dead Time Programming the Maximum Duty Cycle Selecting CSS Additional Information Outline Dimensions Ordering Guide
