Datasheet ISL70444SEH (Intersil) - 6
ПроизводительIntersil
Описание19MHz Radiation Hardened 40V Quad Rail-to-Rail Input - Output, Low-Power Operational Amplifiers
Страниц / Страница25 / 6 — link. to. page. 9. link. to. page. 9. ISL70444SEH. Electrical. …
Версия2017-12-21
Формат / Размер файлаPDF / 2.0 Мб
link. to. page. 9. link. to. page. 9. ISL70444SEH. Electrical. Specifications. VS. =. ±18V. VCM. =. VO. =. 0V,. RL. =. Open,. TA. =. +25°C,. unless. otherwise. noted. Boldface
link to page 9 link to page 9 ISL70444SEH Electrical Specifications VS = ±18V VCM = VO = 0V, RL = Open, TA = +25°C, unless otherwise noted Boldface
ISL70444SEHVFпо запросу
link to page 9 link to page 9 ISL70444SEH Electrical Specifications VS = ±18V VCM = VO = 0V, RL = Open, TA = +25°C, unless otherwise noted. Boldface limits apply across the operating temperature range, -55°C to +125°C. (Continued) MIN MAX PARAMETER SYMBOL TEST CONDITIONS (Note 8) TYP (Note 8) UNIT Output Short-Circuit Current ISNK Sinking; VIN = 0V, VOUT = +18V 10 mA Supply Current/Amplifier IS Unity gain 1.5 1.75 mA 1.95 2.4 mA AC SPECIFICATIONS Gain Bandwidth Product GBW ACL = 101, RL = 10k 19 MHz Voltage Noise Density en f = 10kHz 11.3 nV/√Hz Current Noise Density in f = 10kHz 0.312 pA/√Hz Large Signal Slew Rate SR AV = 1, RL = 10kΩVO = 10VP-P 60 V/µs Electrical Specifications VS = ±2.5V VCM = VO = 0V, RL = Open, TA = +25°C, unless otherwise noted. Boldface limits apply across the operating temperature range, -55°C to +125°C. MIN MAX PARAMETER SYMBOL TEST CONDITIONS (Note 8) TYP (Note 8) UNIT Offset Voltage VOS VCM = 0V 20 400 µV VCM = V+ to V- 80 500 µV Offset Voltage Temperature Coefficient TCVOS VCM = V+ - 2V to V- + 2V 0.5 µV/°C Input Offset Channel-to-Channel Match VOS VCM = V+ 79 800 µV VCM = V- 119 800 µV Input Bias Current IB VCM = 0V 202 340 nA VCM = V+ 182 340 nA VCM = V- 229 580 nA VCM = V+ - 0.5V 181 340 nA VCM = V- + 0.5V 224 580 nA Input Offset Current IOS VCM = V+ to V- -30 0 30 nA -50 0 50 nA Common-Mode Input Voltage Range VCMIR V- V+ V Common-Mode Rejection Ratio CMRR VCM = V- to V+ 92 dB VCM = V- to V+ 70 dB VCM = V+ - 0.5V to V- + 0.5V 91 dB VCM = V+ - 0.5V to V- + 0.5V 74 dB Power Supply Rejection Ratio PSRR V- = -2.5V; V+ = 0.5V to 2.5V 123 dB V+ = 2.5V; V- = -0.5V to -2.5V T 80 dB A = +25°C, +125°C V- = -2.5V; V+ = 0.5V to 2.5V 70 dB V+ = 2.5V; V- = -0.5V to -2.5V TA = -55°CC Open-Loop Gain AVOL RL = 10kΩ to ground 118 dB 90 dB Output Voltage High (VOUT to V+) VOH RL = No load 53 85 mV RL = 10kΩ 53 105 mV RL = 600Ω 400 mV FN8411 Rev.4.00 Page 6 of 25 Jul 6, 2017 Document Outline Related Literature Features Applications Table of Contents Pin Configuration Pin Descriptions Ordering Information Absolute Maximum Ratings Thermal Information Recommended Operating Conditions Electrical Specifications VS = ±18V Electrical Specifications VS = ±2.5V Electrical Specifications VS = ±1.5V Electrical Specifications VS = ±18V - Post Radiation Electrical Specifications VS = ±2.5V - Post Radiation Electrical Specifications VS = ±1.5V - Post Radiation Typical Performance Curves Post High Dose Rate Radiation Characteristics Post Low Dose Rate Radiation Characteristics Applications Information Functional Description Operating Voltage Range Input Performance Input ESD Diode Protection Output Short-Circuit Current Limiting Output Phase Reversal Power Dissipation Unused Channel Configuration Die Characteristics Die Dimensions Interface Materials Glassivation Top Metallization Backside Finish Process Assembly Related Information Substrate Potential Additional Information Worst Case Current Density Transistor Count Weight of Packaged Device Lid Characteristics Metallization Mask Layout Revision History About Intersil Package Outline Drawing
