Datasheet ERA-5+ Full Version (Mini-Circuits) - 7
| Производитель | Mini-Circuits |
| Описание | Drop-In Monolithic Amplifier DC-4 GHz |
| Страниц / Страница | 23 / 7 — MMIC Amplifier. ERA-5+. Definitions:. Input. Output. 1dB. IP3. Noise. … |
| Формат / Размер файла | PDF / 1.3 Мб |
MMIC Amplifier. ERA-5+. Definitions:. Input. Output. 1dB. IP3. Noise. FREQ. Gain. Isolation. Return. Stability. Comp. Figure. Loss. (MHz). (dB). Delta. (dBm)
MMIC Amplifier ERA-5+
Typical Performance Data
Definitions:
Input Return Loss = -S11 (dB) Gain(Power Gain) = S21 (dB) Reverse Isolation = -S12 (dB) Output Return Loss = -S22 (dB) TEST CONDITIONS: Icc = 78mA, Vd = 4.84V @Temperature = +25degC
Input Output 1dB IP3 Noise FREQ Gain Isolation Return Return Stability FREQ Comp. Output Figure Loss Loss Output (MHz) (dB) (dB) (dB) (dB) K Delta (MHz) (dBm) (dBm) (dB)
50 20.72 24.09 25.12 44.79 1.07 0.68 50 37.51 19.34 3.07 100 20.70 24.19 24.95 47.10 1.08 0.67 100 37.90 19.36 3.09 200 20.62 24.09 24.50 47.52 1.08 0.67 200 37.88 19.32 3.05 300 20.53 24.07 24.29 48.87 1.08 0.67 300 37.52 19.36 3.23 400 20.42 24.02 24.03 50.48 1.08 0.66 400 36.86 19.15 3.20 500 20.28 23.95 23.66 48.50 1.09 0.66 500 36.05 19.11 3.18 600 20.13 23.88 23.39 46.37 1.09 0.65 600 35.60 19.09 3.21 700 19.97 23.79 23.05 43.10 1.09 0.64 700 35.32 19.10 3.16 800 19.80 23.73 22.91 39.49 1.10 0.64 800 34.99 18.97 3.12 900 19.61 23.63 22.59 39.17 1.10 0.63 900 34.66 18.58 3.12 1000 19.41 23.52 22.32 37.65 1.11 0.62 1000 34.30 18.51 3.17 1100 19.21 23.40 22.23 36.01 1.11 0.62 1100 34.06 18.55 3.12 1200 19.00 23.28 22.00 35.13 1.12 0.61 1200 33.73 18.50 3.18 1300 18.79 23.17 22.03 34.17 1.12 0.60 1300 33.29 18.44 3.20 1400 18.57 23.03 21.97 33.10 1.13 0.60 1400 32.97 18.33 3.16 1500 18.36 22.93 22.15 31.50 1.13 0.59 1500 32.76 18.15 3.14 1600 18.14 22.76 22.04 31.31 1.14 0.59 1600 32.83 18.02 3.12 1700 17.91 22.62 22.13 30.61 1.14 0.58 1700 32.74 17.91 3.10 1800 17.69 22.48 22.34 29.77 1.15 0.57 1800 32.22 17.69 3.11 2000 17.26 22.17 22.48 28.52 1.15 0.57 1900 31.80 17.46 3.12 2100 17.03 22.03 22.55 27.91 1.16 0.56 2000 31.55 17.28 3.20 2200 16.82 21.86 22.42 27.62 1.16 0.56 2100 31.19 17.17 3.18 2400 16.39 21.57 22.43 26.79 1.17 0.55 2200 30.72 17.11 3.09 2600 15.99 21.21 22.04 25.85 1.17 0.54 2300 30.38 17.03 3.19 2800 15.54 20.92 21.61 25.65 1.18 0.53 2400 30.13 16.82 3.25 3000 15.17 20.57 21.11 24.61 1.18 0.53 2500 29.81 16.46 3.27 3200 14.79 20.26 20.73 23.94 1.19 0.53 2600 29.67 16.19 3.17 3400 14.44 19.87 20.42 22.98 1.18 0.53 2700 29.63 16.15 3.23 3600 14.02 19.65 20.59 23.00 1.20 0.52 2800 29.47 15.87 3.26 4000 13.45 18.87 19.81 21.17 1.18 0.53 2900 29.28 15.73 3.20 4500 12.63 18.18 21.08 19.28 1.18 0.52 3000 29.03 15.63 3.24 5000 11.89 17.50 21.54 16.55 1.18 0.52 3100 28.59 15.36 3.27 6000 10.66 16.16 15.07 12.00 1.14 0.55 3200 28.34 15.13 3.29 7000 9.51 15.16 11.14 9.44 1.09 0.57 3300 28.00 14.98 3.27 8000 8.41 14.29 8.48 7.54 1.03 0.61 3400 27.76 14.78 3.33 9000 6.71 13.85 6.08 5.85 0.99 0.62 3500 27.60 14.41 3.31 10000 4.20 13.66 4.99 4.97 1.02 0.57 3600 27.44 14.28 3.35 11000 1.79 13.41 4.56 4.56 1.07 0.51 3700 27.22 14.06 3.39 12000 -0.21 12.95 4.49 4.45 1.11 0.45 3800 26.94 13.85 3.45 13000 -1.79 12.93 4.34 4.37 1.13 0.39 4000 26.27 13.49 3.37 REV. X1 ERA-5+ 120123 Page 3 of 11 Document Outline ERA-5+ Data Sheet View Data View Graphs Case Style Tape and Reel PCB Layout Eval Board Enviromental Ratings
