Datasheet AD8599 (Analog Devices) - 7
ОписаниеUltralow Distortion, Ultralow Noise Op Amp (Dual)
Страниц / Страница11 / 7 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/16604
Формат / Размер файлаPDF / 67 Кб
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/16604
59 предложений от 22 поставщиков
Рутоника
AD8599ARZ-REEL7
390 ₽
ЧипСити
AD8599ARZ-REEL7
392 ₽
AD8599ARZ-REEL7
от 565 ₽
727GS
AD8599ARZ-REEL
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions Temperature, Device Limits Unit V type S = 15.0 V, VCM = 0 V TA unless otherwise specified Min Max Dynamic performance Slew rate SR AVO = -1, RL = 2 k +25C 01 16 typical V/s AVO = 1, RL = 2 k 15 typical Settling time tS To 0.01%, 10 V step +25C 01 2 typical s Gain bandwidth GBP +25C 01 10 typical MHz product Phase margin M +25C 01 65 typical Degrees Noise performance Peak to peak noise en p-p 0.1 Hz to 10 Hz +25C 01 76 typical nV p-p Voltage noise density en f = 1 kHz +25C 01 1.15 nV / Hz 1.07 typical f = 10 Hz 1.5 Correlated current f = 1 kHz +25C 01 1.9 typical pA / noise Hz f = 10 Hz 4.3 typical Uncorrelated current f = 1 kHz +25C 01 2.3 typical pA / noise Hz f = 10 Hz 5.3 typical Total harmonic THD+N G = 1, R +25C 01 -120 typical dB L  1 k, f = 1 kHz, distortion + noise VRMS = 3 V Channel separation CS f = 10 kHz +25C 01 -120 typical dB 1/ Testing and other quality control techniques are used to the extent deemed necessary to assure product performance over the specified temperature range. Product may not necessarily be tested across the full temperature range and all parameters may not necessarily be tested. In the absence of specific parametric testing, product performance is assured by characterization and/or design.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/16604
REV PAGE 7
