Datasheet AD8041 (Analog Devices) - 2
Описание160 MHz Rail-to-Rail Amplifier with Disable
Страниц / Страница13 / 2 — STANDARD. 5962-96839. MICROCIRCUIT DRAWING
Формат / Размер файлаPDF / 97 Кб
STANDARD 5962-96839 MICROCIRCUIT DRAWING
11 предложений от 10 поставщиков
Микросхема Операционный усилитель, OP Amp Single Volt Fdbk R-R O/P ±6V/12V 8Pin CDIP
ЧипСити
5962-9683901MPA
400 ₽
727GS
5962-9683901MPA
от 3 987 ₽
5962-9683901MPA
5 829 ₽
5962-9683901MPA
1. SCOPE 1.1 Scope. This drawing documents two product assurance class levels consisting of high reliability (device class Q and M) and space application (device class V). A choice of case outlines and lead finishes are available and are reflected in the Part or Identifying Number (PIN). When available, a choice of Radiation Hardness Assurance (RHA) levels is reflected in the PIN. 1.2 PIN. The PIN is as shown in the following example: 5962 R 96839 02 V H A Federal RHA Device Device Case Lead stock class designator type class outline finish designator (see 1.2.1) (see 1.2.2) designator (see 1.2.4) (see 1.2.5) \ / (see 1.2.3) \/ Drawing number 1.2.1 RHA designator. Device classes Q and V RHA marked devices meet the MIL-PRF-38535 specified RHA levels and are marked with the appropriate RHA designator. Device class M RHA marked devices meet the MIL-PRF-38535, appendix A specified RHA levels and are marked with the appropriate RHA designator. A dash (-) indicates a non-RHA device. 1.2.2 Device type(s). The device type(s) identify the circuit function as follows: Device type Generic number Circuit function 01 AD8041 160 MHz rail-to-rail amplifier with disable 02 AD8041 Radiation hardened, 160 MHz rail-to-rail amplifier with disable 03 AD8041 Radiation hardened, 160 MHz rail-to-rail amplifier with disable 1.2.3 Device class designator. The device class designator is a single letter identifying the product assurance level as follows: Device class Device requirements documentation M Vendor self-certification to the requirements for MIL-STD-883 compliant, non- JAN class level B microcircuits in accordance with MIL-PRF-38535, appendix A Q or V Certification and qualification to MIL-PRF-38535 1.2.4 Case outline(s). The case outline(s) are as designated in MIL-STD-1835 and as follows: Outline letter Descriptive designator Terminals Package style P GDIP1-T8 or CDIP2-T8 8 Dual-in-line H GDFP1-F10 or CDFP2-F10 10 Flat pack 1.2.5 Lead finish. The lead finish is as specified in MIL-PRF-38535 for device classes Q and V or MIL-PRF-38535, appendix A for device class M.
STANDARD
SIZE
5962-96839 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 F 2 DSCC FORM 2234 APR 97
