Datasheet OP467 (Analog Devices) - 9
ОписаниеQuad Precision, High Speed Operational Amplifier
Страниц / Страница12 / 9 — STANDARD. 5962-93258. MICROCIRCUIT DRAWING
Формат / Размер файлаPDF / 76 Кб
STANDARD 5962-93258 MICROCIRCUIT DRAWING
38 предложений от 21 поставщиков
727GS
OP467GSZ-REEL
от 14 ₽
ЧипСити
OP467GSZ-REEL
98 ₽
OP467GSZ-REEL
603 ₽
OP467GSZ-REEL
TABLE IIA. Electrical test requirements. Test requirements Subgroups Subgroups (in accordance with (in accordance with MIL-STD-883, MIL-PRF-38535, table III) method 5005, table I) Device Device Device class M class Q class V Interim electrical 1 1 1 parameters (see 4.2) Final electrical 1,2,3,4,5,6 1/ 1,2,3,4,5,6 1/ 1,2,3, 1/ 2/ parameters (see 4.2) 4,5,6 Group A test 1,2,3,4,5,6,7,8,9 1,2,3,4,5,6, 1,2,3,4,5,6, requirements (see 4.4) 7,8,9 7,8,9 Group C end-point electrical 1 1 1 2/ parameters (see 4.4) Group D end-point electrical 1 1 1 parameters (see 4.4) Group E end-point electrical --- --- 1,4 parameters (see 4.4) 1/ PDA applies to subgroup 1. 2/ Delta limits as specified in table IIB shall be required where specified, and the delta limits shall be computed with reference to the previous electrical parameters. TABLE IIB. Burn-in and operating life test delta parameters. TA = +25C. 1/ 2/ Parameter Device type End-Point Delta Unit Min Max Max VIO 01 0.5 ±0.2 mV IIB 01 600 ±250 nA 1/ Deltas are performed at room temperature. 2/ 240 hour burn-in and 1,000 hour operating group C life test. 4.4.2 Group C inspection. The group C inspection end-point electrical parameters shall be as specified in table IIA herein. 4.4.2.1 Additional criteria for device class M. Steady-state life test conditions, method 1005 of MIL-STD-883: a. Test condition B. The test circuit shall be maintained by the manufacturer under document revision level control and shall be made available to the preparing or acquiring activity upon request. The test circuit shall specify the inputs, outputs, biases, and power dissipation, as applicable, in accordance with the intent specified in method 1005 of MIL-STD-883. b. TA = +125C, minimum. c. Test duration: 1,000 hours, except as permitted by method 1005 of MIL-STD-883.
STANDARD
SIZE
5962-93258 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 J 9 DSCC FORM 2234 APR 97
