Datasheet OP290 (Analog Devices) - 2
ОписаниеLow Voltage Dual Precision, Micropower Op Amp
Страниц / Страница10 / 2 — STANDARD. 5962-89783. MICROCIRCUIT DRAWING
Формат / Размер файлаPDF / 100 Кб
STANDARD 5962-89783 MICROCIRCUIT DRAWING
42 предложений от 21 поставщиков
Зенер
Россия и страны ТС
OP290GPZ
2 179 ₽
Контест
OP290GPZ
ЗУМ-СМД
OP290GPZ
OP290GPZ
1. SCOPE 1.1 Scope. This drawing describes device requirements for MIL-STD-883 compliant, non-JAN class level B microcircuits in accordance with MIL-PRF-38535, appendix A. 1.2 Part or Identifying Number (PIN). The complete PIN is as shown in the following example: 5962-89783 01 P A Drawing number Device type Case outline Lead finish (see 1.2.1) (see 1.2.2) (see 1.2.3) 1.2.1 Device type(s). The device type(s) identify the circuit function as follows: Device type Generic number Circuit function 01 OP-290 Precision low voltage micropower dual operational amplifier 1.2.2 Case outline(s). The case outline(s) are as designated in MIL-STD-1835 and as follows: Outline letter Descriptive designator Terminals Package style P GDIP1-T8 or CDIP2-T8 8 Dual-in-line 2 CQCC1-N20 20 Square leadless chip carrier 1.2.3 Lead finish. The lead finish is as specified in MIL-PRF-38535, appendix A. 1.3 Absolute maximum ratings. Supply voltage (VS) ... ±18 V dc Input voltage .. [(-VS) – 20 V] to [(+VS) + 20 V] Differential input voltage .. [(-VS) – 20 V] to [(+VS) + 20 V] Output short-circuit duration .. Continuous Storage temperature range ... -65°C to +150°C Lead temperature range (soldering, 60 seconds) .. +300°C Maximum junction temperature (TJ) .. +175°C Thermal resistance, junction-to-case (θJC) ... See MIL-STD-1835 Thermal resistance, junction-to-ambient (θJA): Case P ... 119°C/W Case 2 ... 120°C/W 1.4 Recommended operating conditions. Supply voltage (VS) ... ±1.5 V dc to ±15 V dc Ambient operating temperature range (TA) ... -55°C to +125°C
STANDARD
SIZE
A 5962-89783 MICROCIRCUIT DRAWING
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 B
2
DSCC FORM 2234 APR 97
