Datasheet MAX4051/A, MAX4052/A, MAX4053/A (Maxim) - 10
ПроизводительMaxim
ОписаниеLow-Voltage, CMOS Analog Multiplexers/Switches
Страниц / Страница19 / 10 — Low-Voltage, CMOS Analog Multiplexers/Switches. …
Версия2
Формат / Размер файлаPDF / 377 Кб
Low-Voltage, CMOS Analog Multiplexers/Switches. ____________________________Typical Operating Characteristics (continued)
Low-Voltage, CMOS Analog Multiplexers/Switches ____________________________Typical Operating Characteristics (continued)
ИС аналогового переключателя
MAX4053AMJE
TradeElectronics
MAX4053AMJE
Maxim
(V+ = +5V, V- = -5V, GND = 0V, TA = +25°C, unless otherwise noted.)
TOTAL HARMONIC DISTORTION FREQUENCY RESPONSE vs. FREQUENCY
0 5 100 V± = ±5V -10 0 600Ω IN AND OUT MAX4051/2/3-09 MAX4051/2/3-10 -20 -5 10 INSERTION LOSS -30 -10 -40 -15 OFF-ISOLATION 1 -50 -20 THD (%) LOSS (dB) -60 -25 PHASE (DEGREES) 0.1 -70 -30 ON PHASE -80 -35 50Ω IN/OUT -90 -40 0.01 0.01 0.1 1 10 100 300 10 100 1k 10k FREQUENCY (MHz) FREQUENCY (Hz)
_____________________________________________________________Pin Descriptions PIN MAX4051/ MAX4052/ MAX4053/ NAME FUNCTION MAX4051A MAX4052A MAX4053A
1, 2, 4, 5, 12, — — NO0–NO7 Analog Switch Inputs 0–7 13, 14, 15 3 — — COM Analog Switch Common — 1, 2, 4, 5 — NO0B–NO3B Analog Switch “B” Inputs 0–3 — 3 15 COMB Analog Switch “B” Common — — 1 NOB Analog Switch “B” Normally Open Input — — 2 NCB Analog Switch “B” Normally Closed Input — — 3 NOA Analog Switch “A” Normally Open Input — — 5 NCA Analog Switch “A” Normally Closed Input
Digital Inhibit Input. Normally connect to GND. Can be driven 6 6 6 INH to logic high to set all switches off. Negative Analog Supply Voltage Input. Connect to GND for 7 7 7 V- single-supply operation. Ground. Connect to digital ground. (Analog signals have no 8 8 8 GND ground reference; they are limited to V+ and V-.) 9 — 11 ADDC Digital Address “C” Input 10 9 10 ADDB Digital Address “B” Input 11 10 9 ADDA Digital Address “A” Input — 11, 12, 14, 15 — NO0A–NO3A Analog Switch “A” Inputs 0–3 — 13 4 COMA Analog Switch “A” Common — — 12 NCC Analog Switch “C” Normally Closed Input — — 13 NOC Analog Switch “C” Normally Open Input — — 14 COMC Analog Switch “C” Common 16 16 16 V+ Positive Analog and Digital Supply Voltage Input
Note:
NO, NC, and COM pins are identical and interchangeable. Any may be considered an input or output; signals pass equally well in both directions.
10 ______________________________________________________________________________________
